SurfTab Twin 11.6
  • d_ne0
    • Nov 2018
    • 22
    SurfTab Twin 11.6
    Hello to everybody!
    I have bought a cheap 11.6 tablet(SurfTab twin wifi) made by firma TREKStore gmbh Germany,with windows 10 from ebay.But booting it asking a pswd.So I cannot use the thing.I have a CH341A programmer and I thought I can reflash clean bios but cannot find any update for this model.The spi chip is Winbond W25Q64FW,I de-soldered it and read data with the programmer.Can someone help me to clean the pswd from bios?
    Thank you all!
    • 21140
    Re: SurfTab Twin 11.6
    Your backup is incomplete. Use AsProgrammer software instead,you`ll find it in the forum. The W25Q64FW is 1.8V
    • d_ne0
      • Nov 2018
      • 22
      Hello!
      Thank you for your answer!
      I will try with as.The software version used is ch341a programmer 1.30 and is saying after reading "Chip Main Memory and buffer same!" as can be seen in picture.Does looks ok or? And yes you´re right,it´s 1.8v chip;before testing I´ve read the datasheet and chip is attached via 1.8v adapter.I will be back soon with the result from asprogrammer.
      Thanks once again!
      • d_ne0
        • Nov 2018
        • 22
        You were right.The size of the dump with asprg 1.41 is 8mb!Here is the dump.Please take a look when you have time.
        All the best!
          • 21140
          The password is ADMIN123
          • d_ne0
            • Nov 2018
            • 22
            Thanks a lot my friend.Question:Can be the bin file modified in order to delete password and be rewritten on the chip?
              • 21140
              It sure can .
              • d_ne0
                • Nov 2018
                • 22
                Thank you for your help and time to look into this.Unfortunately no success after rewriting cleaned bin.Same screen.Maybe I did something wrong?I removed protection,erased chip,opened cleaned bin then rewrite it.
                Strange is that I have not found a way to type the password,while the tab has some sort of keyboard that doesn't work and attaching a keyboard via usb doesn't work either.I have thought if no password required will directly boot into windows.At this point I have no clue how to sort this...Maybe some other people from the forum can come with some ideas?I suspect some settings in BIOS were deactivated...
                Start over again,rewrite one more time?
                  • 21140
                  ok ,next try ... ,see if USB support is ok now .
                  • d_ne0
                    • Nov 2018
                    • 22
                    No luck.With latest its not starting anymore.Its 2 am here,I will try again after few hours of sleep.
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      try... nvram reset , file from SMDflea #7
                      • d_ne0
                        • Nov 2018
                        • 22
                        Hello!Thank you very much guys,really appreciate looking into this,for helping me,wasting a part of your time doing this!!!
                        Right now I am writing last mod into chip and will try again.The patient is in surgeon room... its a real mess I know...
                        • d_ne0
                          • Nov 2018
                          • 22
                          The taste of victory is sweeeeeeet!!!
                          With the last mod tablet is starting!!! you rock guys!
                          Thank you!
                          I take my hat off !!!Really appreciate your time and effort for helping me!
                          • mvatan
                            • Aug 2020
                            • türkiye
                            hello, we have a tablet with SurfTab 11.6 bios password unknown. you solved the problem. I think you managed to reset the winbond chip. Can you share the solution or the file of the chip (.bin) you reset.
                            • peste
                              • Dec 2016
                              • 12933
                              • ROMANIA
                              the solution is at post # 11
                              • d_ne0
                                • Nov 2018
                                • 22
                                Yes,the last .bin written to the chip is from post 11 and was modified thanks to SMDFlea &rioreno;there´s no easy reset process(short a pin to ground solution),it's a de-solder-reflash-resolder back process using CH341A programmer with a 1.8v adapter!!!(or other programmer);Software Asprogrammer.Good luck!
                                • a1309860800
                                  • Mar 2021
                                  • 4
                                  • 香港
                                  hello everyone! My surftab twin 11.6 BIOS is set incorrectly, and the screen is black. I used ch341a to back up. Can you reset it for me
                                  • a1309860800
                                    • Mar 2021
                                    • 4
                                    • 香港
                                    Backup files
                                    • a1309860800
                                      • Mar 2021
                                      • 4
                                      • 香港
                                      Hello, can you reset my BIOS for me? I tried to write the BIOS of 11, but the camera didn't work.
                                      • a1309860800
                                        • Mar 2021
                                        • 4
                                        • 香港
