SurfTab Twin 11.6
  • VeSoN
    • Jun 2017
    • 11
    • turkey
    Re: SurfTab Twin 11.6
    thank you so much :grup:
    • thecustomfhd
      • Jul 2024
      Hey, i was wondering how yall desoldered the BIOS Chip, i unfortunately changed a setting regarding CPU TurboBoost and EIST, and now i only get whitenoise out of the speakers. I tried using a soldering iron + solder wick + flux, but no dice. Ive also noticed that there are test pads underneath/above the chip, which connect to the bios chip, but trying to read via flashrom + raspberry pico, and a voltage divider or diodes, i had no luck, in-circuit seems not possible. What programmer did you use? Where can i order it, plus the 1.8V adapter? Thanks in advance.
      • peste
        • 13924
        • ROMANIA
        .here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
        • thecustomfhd
          • Jul 2024
          I have managed to flash this chip in-circuit, and i can also read it in circuit. Ive grabbed 3 backups of my damaged/bricked bios, and have flashed the bios file that was told that works. And i can confirm that it does work. HOWEVER, the screen is flipped for me, but not the touch. Would someone be willing to erase my bios of any settings i have made? Im assuming i need to clear nvram, but my attempts have been unsuccessful.
          • Grady1952
            Trekstor SurfTab Twin 11.6 (iwork1x) BIOS needed
            by Grady1952
            Hello. I have a SurfTab Twin 11.6 and accidentally flashed the wrong BIOS. I have tried a BIOS that I found on this site but it only shows 2GB of RAM.
            The original BIOS showed the full 4GB. Please post any BIOS that you think may work for me. Thank You!
            Tablet info: i30L64GB16477420283 (purchased as an "iwork1x").
            Some sites have a BIOS "st11432-2b," "N1W6" or similar names but I have not been able to download them.
            BIOS that is installed now is TP15-VT5.3.3.2 (showing 2GB RAM).
            Thanks in advance for any help!
            06-29-2025, 03:32 PM
          • F-18
            MSI twin frozr GTX 750 not shown in device manager
            by F-18
            Hello Newbie here..., few years ago i bought a broken twin frozr gtx 750, seller said that theres heavy stutter issues in every game tested. i inspect it a little and find two tiny capacitor torn out near the pcie x16 gold pins, i assume it will be running in 8x ? the furmark-like gpuz test showed that there's indeed a heavy stutter and low fps but i tried this with EXP GDC and a laptop.
            Few months ago i bought a broken Twin frozr gtx 750ti with unknown issues, i didnt test it and jump straight to thinking that i probably need to solder everything that the gtx 750ti have but gtx 750 didn't...
            11-07-2025, 11:12 AM
          • J.Bach
            Im looking for the boardview and schematic of RTX3050 Twin X2 OC Inno3D
            by J.Bach
            I need assistance; there are knocked-off components on my GPU, which is why I'm looking for the board view and schematic of the RTX3050 Twin X2 OC Inno3D....
            08-23-2025, 03:32 AM
          • dangminhthuongld
            VGA INNO3D GTX 1660 SUPER TWIN X2 6GB boardview
            by dangminhthuongld
            Ple, i need boardview vga inno3d gtx 1660 super twin x2 3XDP-HDMI-GDDR6-6GB
            N166S2-06D6-1712VA15L
            MODEL: PG161
            TKS
            07-01-2025, 01:50 AM
          • jossbnr34
            Msi Geforce RTX 3060 Ti Twin Fan 8G (Missing Capacitors)
            by jossbnr34
            Hi, recently acquired a second-hand MSI Geforce RTX 3060 Ti Twin Fan 8G LHR graphics card. After spending two days trying everything and going crazy because my PC didn't detect it, and the fans weren't spinning, I couldn't figure out where the problem was. Yesterday, I found that some capacitors were missing, and some were broken. I imagine it might have been due to a fall or something like that. I'm trying to find a diagram of my card to see what type of capacitors it uses and their voltage to attempt a repair if possible. I'm new to this, but I have done some simpler soldering repairs on video...
            09-24-2024, 09:40 PM
