https://www.badcaps.net/donate -
Thank you so much for this!
Works on my Thinkpad W550s
I had some trouble with flashrom, but it turned out I was specifying the wrong chip. It's N25Q128..3E. When I used MT25QL128, it just generated a 16MB file full of zeroes.Comment
Thank you very much. What I found out after replacing the crappy test clip with a better one was the problem with my patched.bin. It flashed perfectly. Then I thought I screwed things up after flashing the original BIOS back on as it wasn't properly powering on. Well the adapter I had was crappy as well. Such a chore to figure out your own crappy parts sitting around.
End result was a pass for no more lock! Thanks to the forum!!Comment
https://www.badcaps.net/donateComment
If mobo code "Wistron Genesis-1 LGS-1 11246-1" then password is inside small eeprom U42
http://www.ja.axxs.net/x1_carbon.htmComment
Attached Files↵
Attached FilesComment
Hi, i got a problem with procedure to patch lenovo l380 20m8.
I save my original bios twice before to start (2 files joined in MyBackup)
I found on your page a file l380 original patched (joined)
So when i save my bios, i erase and i flash with patch, i see ID and valid, do spacebar twice.
After i turn off, erase again to flash with my original bios backup.
But my computer not boot, where is my mistake ?
Thanks for helpLast edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
try...Attached FilesComment
Hi, Im having problems unlocking bios with the provided method, I have several of these unit to unlock. I have included both dump files and and the auto patcher tool that I have downloaded from this thread. The Laptop is a Lenovo ThinkPad L480 with an Intel I5 8250U CPU, The Winbond Chip is W25Q128JVSQ. If someone can get this unlocked and then show me how so I can do the rest of the Laptops it would be grateful.Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
Hi, Im having problems unlocking bios with the provided method, I have several of these unit to unlock. I have included both dump files and and the auto patcher tool that I have downloaded from this thread. The Laptop is a Lenovo ThinkPad L480 with an Intel I5 8250U CPU, The Winbond Chip is W25Q128JVSQ. If someone can get this unlocked and then show me how so I can do the rest of the Laptops it would be grateful.Comment
Please see attached photos below.Last edited by TJJones94; 03-08-2022, 08:08 AM.Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
