 Thank you so much for this!
 Works on my Thinkpad W550s
 I had some trouble with flashrom, but it turned out I was specifying the wrong chip. It's N25Q128..3E. When I used MT25QL128, it just generated a 16MB file full of zeroes.Comment
 Thank you very much. What I found out after replacing the crappy test clip with a better one was the problem with my patched.bin. It flashed perfectly. Then I thought I screwed things up after flashing the original BIOS back on as it wasn't properly powering on. Well the adapter I had was crappy as well. Such a chore to figure out your own crappy parts sitting around.
 End result was a pass for no more lock! Thanks to the forum!!Comment
 https://www.badcaps.net/donateComment
 Thanks for the bios code any idea how to remove the computrace ?If mobo code "Wistron Genesis-1 LGS-1 11246-1" then password is inside small eeprom U42
 http://www.ja.axxs.net/x1_carbon.htmComment
 Attached Files↵
 try...Attached FilesComment
 Hi, i got a problem with procedure to patch lenovo l380 20m8.
 I save my original bios twice before to start (2 files joined in MyBackup)
 I found on your page a file l380 original patched (joined)
 So when i save my bios, i erase and i flash with patch, i see ID and valid, do spacebar twice.
 After i turn off, erase again to flash with my original bios backup.
 But my computer not boot, where is my mistake ?
 Thanks for helpLast edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
 Hi, Im having problems unlocking bios with the provided method, I have several of these unit to unlock. I have included both dump files and and the auto patcher tool that I have downloaded from this thread. The Laptop is a Lenovo ThinkPad L480 with an Intel I5 8250U CPU, The Winbond Chip is W25Q128JVSQ. If someone can get this unlocked and then show me how so I can do the rest of the Laptops it would be grateful.Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
 Is the motherboard model number NM-B461 ,if so it has an ITE IO chip ,not an SMSC MEC .Try flashing the ITE chip.Hi, Im having problems unlocking bios with the provided method, I have several of these unit to unlock. I have included both dump files and and the auto patcher tool that I have downloaded from this thread. The Laptop is a Lenovo ThinkPad L480 with an Intel I5 8250U CPU, The Winbond Chip is W25Q128JVSQ. If someone can get this unlocked and then show me how so I can do the rest of the Laptops it would be grateful.Comment
 I can confirm that is the Motherboard model, Would the ITE IO chip be on the back side of the board (opposite side to the ram).
 Please see attached photos below.Last edited by TJJones94; 03-08-2022, 08:08 AM.Comment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
