    • 22312
    Originally posted by linxz
    Hello Maxpower3
    i got Lenovo M910q with password protected BIOS
    Can you help me to patch the bios.thanks!
    Off-topic .Desktop pc bios requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=15 .The patcher does not support it.
    • adin
      • Aug 2021
      • 39
      • australia
      #822
      worked perfect x280 !
      • danandrei96
        • Dec 2018
        • 17
        #823
        @AAAC well I'm embarrassed. Sorry about that. It seems that pressing "Enter" at the boot screen freezes the machine completely, so it won't respond if you press F1 after. I just powered it down and pressed F1 straight away at the lenovo logo, worked like a charm. Thanks a lot
        • sabah
          • Jun 2018
          • 6
          • iraq
          #824
          thanks for the file I download it ,but not working in my laptop win 10 64bit. any help please
          • linxz
            • 24
            Thank you!
            • MeoT
              • Aug 2021
              Which tools do you recommend to backup and flash the BIOS on a lenovo P72 ?
              • atomx
                • Aug 2021
                #827
                So I'm trying to give it a go but getting stuck here:
                Code:
                Using UEFIReplace to inject 2 DXE drivers...
                [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                Looking for volumes to patch...
                Traceback (most recent call last):
                 File "c:\lenbios\lenbios\patch\autopatch.py", line 301, in <module>
                  patch(filename)
                 File "c:\lenbios\lenbios\patch\autopatch.py", line 171, in patch
                  clean(patched_filename)
                 File "c:\lenbios\lenbios\patch\autopatch.py", line 188, in clean
                  volume = load_patched_volume(p)
                 File "c:\lenbios\lenbios\patch\autopatch.py", line 234, in load_patched_volume
                  size = int.from_bytes(header[16:19], 'little')
                AttributeError: type object 'int' has no attribute 'from_bytes'
                To add up, all of my IC reads return the same md5 regardless of the software used
                  • 22312
                  Laptop model number ?
                  • atomx
                    • Aug 2021
                    #829
                    Oops, my bad. It's an X280, Winbond 25Q128JVSQ, using a CH341a + clip.
                    • atomx
                      • Aug 2021
                      #830
                      Can't edit the post so just following up with the fix: because it was an obvious python issue, placed all the auto-patcher files in the /AppData/Local/Programs/Python folder and ran from there with zero issues.
                      Thanks!
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1376
                        • France
                        #831
                        Code:
                          patch(filename)
                        try may be
                        https://www.badcaps.net/forum/showpo...postcount=1444
                        • MeoT
                          • Aug 2021
                          Hello, can someone guide me on how to remove the supervisor password on a lenovo P72.
                          Thank you!
                          • neverexisted
                            • Nov 2012
                            • 76
                            I just get this no matter what I do:
                            1.bin is corrupted or does not contain a valid dump.
                            There was an error... Aborting.
                            T420i and E531 / E530
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1376
                              • France
                              #834
                              model with P24s08 ?
                              autopatcher don't work
                              look
                              http://www.ja.axxs.net/eeprom_location.htm
                              • albodriy
                                • Aug 2021
                                • Russia
                                #835
                                Hello everyone! I have bad English, sorry. I have a laptop Thinkpad t480s type 20L7-001LGE.
                                And it looks like I broke it. I made a dump but didn't check it. I tried to flash it and got a black screen.
                                The script did not work, saying that the dump: "Is corrupted or does not contain a valid dump".
                                I tried to flash someone else's dump from a user post from this forum. I got to 7 points,
                                but then when I flashed someone else's original dump I got a black screen. Everything is bad? Here is my broken dump.
                                • malangg
                                  • Sep 2014
                                  • 34
                                  #836
                                  Hi, I tried on x390, but getting beep and back screen only..
                                  any help will be aprreciated..
                                  thanks
                                  • srpr
                                    • Oct 2019
                                    • 12
                                    • turkey
                                    #837
                                    can someone help me? I failed.
                                    • kiknusko
                                      kiknusko
                                      • Jan 2019
                                      • 26
                                      • Slovensko
                                      #838
                                      Here
                                      • Soo
                                        • May 2016
                                        • 6
                                        • Srbija
                                        #839
                                        Helo
                                        I have a lenovo Yoga 11e can some one help with bios patch?
                                        bios
                                          • 22312
                                          Originally posted by Soo
                                          Helo
                                          bios
                                          Read some other Yoga 11e threads, the patcher doesn`t work.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
