 Hello Autopatcher works here is the result you can try it.Attached FilesComment
 Try this, maybe work. If you can entering bios menu without entering password, then follow instructions on post 1 from inside the bios setup security menu. Don't forget to clear every security & fingerprintAttached FilesComment
 In a Lenovo T540p notebook there are two BIOS chips you need the one with 4MB.
 Because your chip with 8MB cannot be patched.
 https://www.allservice.ro/forum/images/T540p_bios.jpgLast edited by Markus1741; 04-06-2021, 11:33 PM.Comment
 Hi, you can try this.
 Patched with Autopatcher!Comment
 Try this ... good luck!Comment
 thank you so much. but it not work. no display on, sound beep coming.Comment
 @black0hackers: Try this patch and report results, instructions included.Attached FilesComment
 FYI:
 I destroyed the diode D12 while updating the chip of my T450, because I first connected the adapter wrong.
 If your laptop does not turn on anymore (screen stays black and fan turns on briefly) then check the diodeComment
 Hello.
 Can anyone please help me?
 Lenovo W530 (Kendo-4 platform), the password is in the BIOS.
 an attempt to use a patch from a starttopic results in a patcher error.
 Moreover, if I patch the same 4MB dump from the T540 (Kendo-1 platform),D:\L>autopatch.cmd 4.bin
 Using UEFIReplace to inject 2 DXE drivers...
 [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
 4.bin is corrupted or does not contain a valid dump.
 There was an error... Aborting.
 everything goes well. I am attaching the original dump.D:\L>autopatch.cmd 5.bin
 [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
 Looking for volumes to patch...
 [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
 Not found... Skipping.
 Done.
 PATCH FILE: 5_PATCHED.bin
 Good luck.Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
