Hi try this!Attached Filesif you find these attachements useful please consider making a small donation to the site
Two things possible your original file is not correct (big problem) or I would reassemble the bottom case and try again.Attached Filesif you find these attachements useful please consider making a small donation to the site
[QUOTE=Markus1741;1035640]Two things possible your original file is not correct (big problem) or I would reassemble the bottom case and try again.Attached Filesif you find these attachements useful please consider making a small donation to the site
EDIT: I got it running, exactly like described in Post #1 :-)
But the W25Q128FV needs to be erased before each programming step.
Many thanks !!!
Hi everyboy,
can someone help me with my T460p Laptop - Type 20FW ?
I backuped the original Bios and used the autopatcher but now the screen doesn't even turn on anymore.
orig.bin
SHA1: 98c542daec2de04d50a19620583c8cdc7018479e
IC says 250128FVSQ-1643, I took the W25Q128FV-Settings in AsProgrammer.
Help would be very appreciated.
Thanks and Greetings from Hamburg,Germany,
Banane
Maybe you could try this!
Many thanks !!!
Hi everyboy,
orig.bin
Banane
It can`t be patched,at the moment only allservice can do it in-house https://www.allservice.ro/forum/viewtopic.php?t=3044Comment
Or if you have an EC/KBC programmer you can READ, ERASE and PROGRAM EC/KBC, disconnect all source of energy for 1-2 minutes, then reconnect and use Lenovo Maintenance Utilities (UEFI version) to enter Model Number, Serial Number and other data.
As far as I know ThinkPad X390 has NUVOTON embedded controller, so you may be able to program it using keyboard connector on motherboard.Comment
Sir pls upload dell bios factory reset patch (blank & model)Comment
Try this ...Attached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Today, 04:04 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
