  • Bill_Carson
    • Mar 2021
    • 8
    Good evening,
    I wanted to check if this will work for a Lenovo P51s 20JY ?
    I have a supervisor password that i need to wipe.
    thank you.
    • Mazorca
      • Jan 2017
      • 463
      I have two Lenovo x250 that I am having trouble with, both with svp and at least one with computrace that showed up when I cleaned the ME region trying to get it to boot up. I have been successful with an X240 earlier, but no luck so far. I have included the generated patched files to both and yes, I did try the unlocked X250 patch files from Lenovo Unlock Dxe Driver Bios Collection. Same result, no beeps, black screen, mA consumption from 6 to 125 then back to 6, in a loop. Yes, I did find the security switch and another white switch, which corresponds to a hole in the backplate(cmos reset?)
      • Manjunathrawoor
        MBR
        • Mar 2021
        • 42
        • India
        #463
        Hi team 128 MB working fine with autopatch, but 32 MB file is failed here , please look in to this and please suggest us
        • Mazorca
          • Jan 2017
          • 463
          Update: Nevermind, I got one done and working on the other one. Problem was that I was desoldering and soldering with hot air station and it wasn't soldering correctly, there is a lump of lead on the center of the BIOS chip pad, made it rise a bit, legs weren't reaching down I think. I cleaned all pads, tinned them again and laptop boots perfectly with the autopatch bin file. Let that be a teaching moment for me.
          • s0ulf
            • Mar 2021
            • România
            #465
            Hi! Does this work for a lenovo T560s? I have a supervisor password and computrace enabled & activated and I read several pages ago that removing the supervisor password using the auto-patcher could also disable the computrace? Thanks.
            • AAAC
              • Jan 2020
              • 459
              • Mexico
              #466
              @s0ulf
              The AllService solution that the Auto-patcher uses is a 2-in-1 solution, it will (1)reset the Supervisor Password and it will (2)deactivate CompuTrace (if enabled/active).
              • Bill_Carson
                • Mar 2021
                • 8
                Please can someone tell me what my SVR password is so I can go in and remove it?
                I have used the CH341a to save the bios 3 times to make sure the file is the same each time and no corruption.
                Please see the attached 1.zip file. your help is greatly appreciated.
                Lenovo P51s 20JY
                zip contains:
                Size: 16777216 bytes (16 MiB)
                SHA256: A1E7278A3855F13B2567C4775F3D6A0CC8F0FAFBD3E9FF30B8AA8EB77831D438
                • Markus1741
                  • Sep 2020
                  • 980
                  • N/A
                  #468
                  Lenovo P51s 20JY
                  zip contains:
                  Hi try this!
                  • Bill_Carson
                    • Mar 2021
                    • 8
                    Hi try this!
                    Hi Markus1741 thank you.
                    do I just need to flash the bios chip with the attached file?
                    • Kramdas
                      • Mar 2015
                      • 5
                      • india
                      #470
                      Laptop getting Shutdown after pressing F1 while unlock with patched bios
                      • Kramdas
                        • Mar 2015
                        • 5
                        • india
                        #471
                        Kindly patch this file.
                        • Bill_Carson
                          • Mar 2021
                          • 8
                          Hi try this!
                          WORKS A TREAT!!!
                          followed the steps on page 1 of this thread, works great!
                          thank you, God bless you!
                          • speedjunky
                            • Mar 2021
                            • Österreich
                            #473
                            Hello, anyone can help me please to patch my laptop?
                            Its a Thinkpad X1 Yoga 2nd Gen.
                            Thanks a lot
                            • Markus1741
                              • Sep 2020
                              • 980
                              • N/A
                              #474
                              Thanks a lot
                              Hi you can try this!
                              • speedjunky
                                • Mar 2021
                                • Österreich
                                #475
                                It worked on the first try.
                                • s0ulf
                                  • Mar 2021
                                  • România
                                  #476
                                  Trying to do this on a t460s, i patched the file but after flashing it when I try to turn the laptop on the screen is black and the fans spins for 3-5s then it seems like it restarts. Any ideas what could cause this? Thanks.
                                  EDIT: Reflashing with the original dump does the same thing
                                  How fucked am I?
                                  • Markus1741
                                    • Sep 2020
                                    • 980
                                    • N/A
                                    #477
                                    Glad to hear that it worked.
                                    I think it is very important to have a good backup of the original BIOS file.
                                    I always read it out three times myself.
                                    Then I compare these three with MD5SUM to see if they are identical.
                                    Only then can the whole thing continue successfully.
                                    With best regards :
                                    • Mazorca
                                      • Jan 2017
                                      • 463
                                      @s0ulf: That's what happened to me. Solder chip with soldering iron, check for legs fully joined to pads, no bridges. Is chip correctly positioned? Not upside down? Check with microscope if available, or invest on one, it will pay for itself.
                                      • s0ulf
                                        • Mar 2021
                                        • România
                                        #479
                                        @Mazorca I didn't desolder it, I used the testing clip
                                        • Ferrum
                                          • Mar 2021
                                          • 5
                                          • Russia
                                          #480
                                          the file is corrupted or not supported
                                          Thanks to the author!
                                          Everything worked for me right away.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
