  • tpchs
    • Mar 2015
    • mexico
    #4021
    Originally posted by Knucklegrumble
    lenovo_autopatcher_0.2.zip Hello everyone!
    In the past several weeks I've learned a lot from this forum and its community especially from all the folks who contributed to THIS thread
    With some trial and error I was able to reliably patch BIOS dumps for SVP-locked Lenovo machines up to the 8th generation using the info, tools, and files provided on this forum. After some practice and positive feedback from users I helped I've noticed that, once learned, the process is fairly straightforward, so I've developed a small python script to automate it and allow everyone to patch their own binaries without having to ask for help and wait.
    This is my way to give back to the community. Also I am lazy... lol.
    DISCLAIMER
    1. THIS SCRIPT IS FREE AND IS INTENDED FOR EDUCATIONAL PURPOSES ONLY.
      You CAN download it, modify it, redistribute it, etc. I only ask that you DON'T sell it or try to make a profit from it, and that you please credit the authors for the time and work they put into it.
    2. I TAKE NO CREDIT FOR CREATING THE DXE DRIVERS OR ANY OF THE FILES THAT MAKE UP THE PATCH ITSELF.
      I've only developed the python script that automates the process and puts it all together.
    3. I TAKE NO RESPONSIBILITY FOR ANY DAMAGE YOU DO TO YOUR MACHINE, YOUR PETS, YOUR HOUSE, YOUR LIFE, AND THE SPACE-TIME CONTINUUM
      Making this kind of modifications is risky and might leave you with an unusable/broken machine.
      The script is not perfect by any means, and while I haven't bricked any hardware (yet) I can't promise that won't happen to you.
      USE IT AT YOUR OWN RISK.
    With that out of the way, using it is pretty simple and it should work on both Windows and Linux as long as you have Python installed https://www.python.org/downloads/.
    Just download the zip file and extract it. You'll get a folder named "lenovo_autopatcher" with the following content:
    IMPORTANT: Before applying the patch make sure you verify that your original image is not corrupted by dumping 1 or 2 additional images from your bios chip and comparing them. The original dump is THE ONLY WAY to recover your machine if something goes wrong!
    From command line use either autopatch.cmd (Windows) or autopatch.sh (Linux) as follows:
    autopatch
    THAT'S IT!
    The command will generate either your_bios_image_PATCHED.ext or your_bios_image_PATCHED_CLEAN.ext depending on the type of BIOS you are patching. The original dump will be left unchanged.
    autopatch -h will output the help info for the command
    autopatch --howto will output the following instructions on how to use the patched image:
    [ HOW TO USE THE PATCH ]
    STEP 1: Flash and replace current BIOS with the generated patch file
    STEP 2: Boot the machine
    STEP 3: Press ENTER/F1/etc. to enter BIOS settings
    STEP 4: Enter any character when asked for Supervisor Password
    STEP 5: Press enter when it shows Hardware ID
    STEP 6: Press space bar 2x when asked
    STEP 7: Turn off machine
    STEP 8: Restore original BIOS
    STEP 9: Reset BIOS settings to factory default
    [ NOTES ]
    When booting the patched BIOS you might have to:
    - Hold the anti-tamper switch down the whole time (use tape)
    - Remove the hard disk or replace it with a locked one
    Finally, I would be grateful if you could report any bugs, errors, problems, or general feedback in this thread so that I can make improvements to the script.
    Thank you, and enjoy!
    Download -> https://www.badcaps.net/filedata/fetch?id=3166264
    i have a thinkpad l480 after the patching only stay in entering setup some one can helpme
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
