  • AAAC
    • Jan 2020
    • 458
    • Mexico
    #341
    @palembang
    ThinkPad X1 Carbon Gen7 has a Self-Healing bios, if you patch the file it will self recover in the best case and patched file custom code won't even execute.
    • palembang
      • Sep 2014
      • 15
      • indonesia
      #342
      Originally posted by AAAC
      @palembang
      you're right friend, patch not workin. nvram no found for patching with autopatcher. even bios update will bios auto healing no change.
      I am really confused to continue the next stage. I have used uefitool ne and IDA and there is no progress. any suggestions for the next stage?
      • leemobile2306
        • Mar 2018
        • 17
        #343
        hi could someone patch this for me please
        i cant get the cmd to run today for some reason
        thanks
        • bright3739
          • Jan 2021
          • nigeria
          #344
          i need lenovo t440s pathc
          • Markus1741
            • Sep 2020
            • 946
            • N/A
            #345
            thanks
            Hi Try This!
            • leemobile2306
              • Mar 2018
              • 17
              #346
              Hi Try This!
              hi thanks for that but it just beeps now
              • Markus1741
                • Sep 2020
                • 946
                • N/A
                #347
                The patch for Lenovo T450 already worked for me.
                Did you notice that from post one.
                "When booting the patched BIOS you might have to:
                - Hold the anti-tamper switch down the whole time (use tape)
                - Remove the hard disk or replace it with a locked one"
                I always mount the bottom case and then i start the notebook with the patch.
                • Markus1741
                  • Sep 2020
                  • 946
                  • N/A
                  #348
                  Have you reassembled the ram?
                  • Pasha_Lu
                    • May 2020
                    • 11
                    • Ukraine
                    #349
                    Lenovo T460s is OK. Thank you.
                    • AAAC
                      • Jan 2020
                      • 458
                      • Mexico
                      #350
                      @palembang
                      A friend have unlocked 2 ThinkPad T490 using a EC/KBC programmer, it's more complicated, but it can be done. I recommend to investigate what's the EC/KBC chip in your X1 Carbon Gen7, for EC/KBC programmer you need to locate the JTAG signals, you may have to solder wires to the motherboard to connect them to the programmer and remove/install a resistor to enable JTAG interface (just change resistor from PULL-UP to PULL-DOWN position, signal is LOW-ACTIVE). Some EC/KBC can be programmed through the keyboard connector using a FPC cable.
                      Or you can wait for a more easier solution to be available.
                      • aetguitars
                        • Jan 2021
                        Originally posted by m3tauser
                        So short update from me: managed to patch the bios. in my case the problem was that I had to versions of Python, 2 and 3, installed. So i had first to uninstall python2 and after to modify autopatcher.py file and manually change from python to python3 (i am using ubuntu 20.04) and after that the process went straightforward.
                        So I can confirm that the patch works in Lenovo Thinkpad t460p.
                        thanks to all who made it possible!
                        Could you tell me where the BIOS chip is on the T460p?
                        Thank you.
                        • UkNik
                          • Jan 2021
                          • Moscow
                          #352
                          Knucklegrumble, thank you very much! Lenovo L380 password was successfully reset whiten your solution.
                          • aydarin1
                            • Jan 2021
                            • 11
                            • russia
                            #353
                            Hi! can someone help me make a patch, I can't do it, I will be grateful!
                            • aydarin1
                              • Jan 2021
                              • 11
                              • russia
                              #354
                              https://www.badcaps.net/forum/attach...1&d=1610986702
                              • Markus1741
                                • Sep 2020
                                • 946
                                • N/A
                                #355
                                Hi try this!
                                • aydarin1
                                  • Jan 2021
                                  • 11
                                  • russia
                                  #356
                                  Thank you so much
                                  • darkeye
                                    • Dec 2020
                                    • germany
                                    #357
                                    could somebody patch a p52 bios with 32mb.
                                    • Nex_000
                                      • Jan 2021
                                      • Italia
                                      #358
                                      Hello, could someone please send me the bios file for lenovo x1 yoga 3th generation 20 EL. Thanks
                                      • Markus1741
                                        • Sep 2020
                                        • 946
                                        • N/A
                                        #359
                                        I had some problems with the Python script on Linux Ubuntu.
                                        For everyone who also gets an error message in Linux helps.
                                        SHOW=$(sudo find $HOME -iname 'UEFIreplace'); chmod +x $SHOW
                                        • mrserbest
                                          • Feb 2015
                                          • 10
                                          • türkiye
                                          #360
                                          i need lenovo t460s patch please orj dump attach
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            Yesterday, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
