It can`t be patched,it doesn`t have an SMSC MEC chip. The password is stored in a small chip P24S08 or similar.The pins on the chip can be shorted together or there`s another method reading the chip - https://www.badcaps.net/forum/showth...ghlight=P24S08
https://www.badcaps.net/forum/search...rchid=20984473
.Last edited by SMDFlea; 01-02-2021, 05:09 AM.Comment
Finally , i use the Maxpower3 patched bios and it works .
Thank you.
Post : #11
https://www.badcaps.net/forum/showthread.php?t=81573Comment
read post #1 all an each steps are there including ''lenovo_autopatcher_0.2''
https://www.badcaps.net/forum/showpo...52&postcount=1Comment
Hi i have the same problem on T450 vPro 2x5 beeping after flashing the patched file. The CH341A detects the chip as W25Q128BV. Attaching some screenshots and the original dump. Can you help please? ThanksLast edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
It worked if someone needed itAttached FilesComment
Hi, I'm new to this so will be having a go in the morning, I've read all 17 pages of this thread but would just like to know if i need to disconnect the cmos battery and or power cell before flashing a yoga 370 ? thanks in advanceComment
thank you, tiring it now, wish me luck lolComment
Maybe someone give me help !
I try this patch with Lenovo thinkpad x390 yoga , when first try the patched file the lap is on for 10 seconds ( black screen) than off, than on whith a continious beep ( always black screen ).
this my main dumpLast edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
thanks this working for many lenovo model...Comment
Hello. I did a BIOS patch via autopatcher. After removing the password, I recovered the original BIOS and turn on laptop, but with the BIOS battery inserted and the HDD connected. Only the power LED flashes and the laptop does not start. Is it possible that the KBC dump is damaged? Please give me a hint. Thank you.Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
