  • adamgouadma
    • Jul 2017
    • 202
    • setif
    #3521
    Hello everyone, I need help password t470S NM-B081
    • Guest
      #3522
      hopefully its not too late to ask for help lol,
      thinkpad t480 specs:
      Type 20L6-S5NY00
      CPU Intel i7-8650U
      bios version: 1.52​
      supervisor password-locked
      i used both autopatchers posted by op, even tried pushing the tamper button and still got seven beeps (Virtual Mode Exception Error) and the device stayed on both times.
      Flashing back to og bios fixes that. i've done hours of digging on this thread and have yet to find a solution, is it true that with my model a ch341a programmer won't work no matter what?
      • Drwatson32
        • Nov 2024
        Good morning, very much a similar story to the previous poster, I've followed the steps meticulously, but I cannot get my T480 to POST after writing the patched BIOS. (Both phases of the python script appear to complete successfully.) I would get a beep code, however, though my phone app already lost it under recents. Google revealed this to be corrupt BIOS related. Fortunately, the machine works after restoring the initial backup. (There is an admin password) I hate to ask, but have gotten as deep into the troubleshooting rabbit hole as I think I can manage, but if this could be checked and fixed, I would be most thankful.
        This is a T480 type 20L6S68t23
        system unit serial: PF1F2FR3
        system board serial: L1HF8AF0875
        • Guest
          #3524
          Type 20L6-S5NY00
          CPU Intel i7-8650U
          bios version: 1.52
          also, what the qr code says on the motherboard:
          1227716604265
          43116M012OS
          ET40 10G2
          2H_2018-08-25
          what it says under the fan on the motherboard:
          ET480 NM-B501
          Rev:1.0
          2018-03-05
          Made In China
          Q198
          how would i replicate kordex35kordex35's success on my Type 20L6-S5NY00 W25Q128JV bios chip?
          • shiyab
            • Sep 2023
            • 1608
            • india
            #3525
            need Programming ec MEC
            • tutzu
              • Apr 2021
              • 9
              • romania
              #3526
              Hi guys, i canot patch my bin file. can somedody do it ? thanks
              • tutzu
                • Apr 2021
                • 9
                • romania
                #3527
                done , i do it
                • kordex35
                  • Apr 2015
                  • 49
                  • Polska
                  #3528
                  ok
                  • Alex499
                    • Dec 2024
                    • RUS
                    #3529
                    Originally posted by dhan
                    HELLO,
                    I have a problem.
                    I managed to patched the bios, but I accidentally deleted the original bin file.
                    Is there a way to recover or do a vice versa to undo the patched, to be able to have the original bios.
                    btw, shift delete was used, the orig bin file is not in the recycle bin.
                    thank you.
                    attached the patched bin file.
                    laptop: thinkpad T440
                    type: 20B7
                    SN: PF-01MC28
                    Thank you! I unlocked my laptop using your patch.
                    • nykitel
                      • Oct 2019
                      • 5
                      • romania
                      #3530
                      good evening team, I managed to use the patch on a lenovo L480 successfully
                      but I have problems with a lenovo E485 that does not work with this patch because it is an AMD platform
                      my question is what options do I have for the supervisor password romoval ?
                      • Benuto
                        • Mar 2021
                        something
                        • motanya
                          • Nov 2021
                          • 162
                          • Kenya
                          #3532
                          Hello team has anyone managed to patch bios password for this laptop, if it is not possible is someone able to disable Absolute Persistence?
                          Lenovo Thinkpad T14s Gen 2i
                          HT4B1/HX3B0
                          NM-D362 Rev 4.0
                          SN:PC2EXE71
                          Type: 20WN​
                          • crunkatron
                            • Dec 2024
                            • Japan
                            #3533
                            First off, I would like to say THANK YOU for this software.
                            I was able to successfully unlock my bios locked Thinkpad X1 Carbon Gen 6 (20KH) laptop.
                            For those of you with the same model, here are a couple of notes.
                            I started off using AsProgrammer 2.1.0 and was able to successfully read and backup the bios on the chip.
                            However, using this software I was unable to write the patched bios back on the chip.
                            After searching through this forum I came across a post recommending NeoProgrammer V2.2.0.8 and using that software I was able to write the patched bios to the chip.
                            I then used NeoPrgrammer to rewrite my original bios back on the chip after following the Autopatcher instructions.
                            So if you were having the same issue as I was, switching to NeoProgrammer software solved the problem.
                            • sweemann
                              • Nov 2024
                              • 9
                              First of all thanks for this Script. I managed to pass my Bios password succesfully on a Lenovo T480s. The Problem i have now is that i have an extreme Bios time for about 60 seconds and more before i see the Lenovo splash screen.
                              After i enter the Bios i saw that there ist no version written in the line Intel ME Version. Does anyone has the same Problem and how to fix it ? Or is it neccesary to have the version written here ? Maybe it has something to do with the extended Bios Time.
                              thanks in advance
                              • graf46
                                • Sep 2022
                                • 7
                                • украина
                                #3535
                                Thanks for the work. The problem is this - I reset the password with the auto patcher - x380 yoga. It turns on in the BIOS, but nvme is not displayed. Live USB loads. After turning it off, it does not turn on for the second time. You need to disconnect all power supplies and CMOS/ Thanks in advance. Peace to all.
                                • graf46
                                  • Sep 2022
                                  • 7
                                  • украина
                                  #3536
                                  thinkpad t460s password reset. enters bios. does not display, does not see nvme/liveusb, loads. thanks for the answers in advance.
                                  • Garry Larry
                                    • Dec 2024
                                    Hey Y'all
                                    Unfortunately I have not been able to get my patched BIOS to work on my X280.
                                    The autopatch script seems to be working from the output with no errors (see attached image).
                                    During boot there is no display, and I get beep code 0285 (TCG-compliant functionality related error / Might be TPM initialization failure).
                                    I can re-flash my BIOS chip with the original unpatched BIOS and boot normally.
                                    Would anyone be able to help or explain why it might not be working in my case?
                                    Thanks.
                                    Hardware Specifications |
                                    Machine Type Model : Lenovo X280 20KF-CTO1WW
                                    System Unit S/N : PC15ZW0H
                                    System Board S/N : L1HF936010A
                                    • graf46
                                      • Sep 2022
                                      • 7
                                      • украина
                                      #3538
                                      you have to wait 15-20 minutes
                                      • alfredposadas09
                                        • Aug 2020
                                        • 342
                                        • Philippines
                                        #3539
                                        Originally posted by Garry Larry
                                        Hey Y'all
                                        Thanks.
                                        perform clean ,me
                                        • thelibrary
                                          • Jul 2018
                                          • 18
                                          • philippines
                                          #3540
                                          can please patched? bios locked
                                          DL470 nm-b021 rev 1.0
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
