https://filetransfer.io/data-package/XXWffcco#link
Cant upload as attachment, it doesnt allow .bin extension
I put in link initial and patched one I did as instructed
Its 20HQ - DX120 NM-B141Comment
with winrar (.rar) or .ziphttps://filetransfer.io/data-package/XXWffcco#link
Cant upload as attachment, it doesnt allow .bin extensionComment
attached nowAttached Filesif you find these attachements useful please consider making a small donation to the site
try initial patched, see open setupAttached Filesif you find these attachements useful please consider making a small donation to the site
it worked, thanks man you are the king,
im in bios settings and spv disabled, i did "load setup defaults" as well. I closed computrace from enabled to as "permanently disabled" , do you know if extra steps needed further?
can I use laptop with this bios bin or I need to find clean default bin?
Thanks!Comment
use this one, see if everything works ssd /lan etc ..
Thanks!
you lost the windows key, if necessary ask for itComment
Hi, I have used the search function copiously, and tried to follow a few leads in regards to getting a beep code of 0285, TCG-compliant functionality-related error (might be the TPM initialization failure). I've tried disabling TPM through powershell, tried autopatch script several times, and each time I try and boot with the modified BIOS I get a 0285 beep code. Using the dumped bios works fine. Any tips or knowhow on how to fix this? In UEFITool I found that the patched bios has a "FfsParser::checkProtectedRanges: Phoenix protected range [970000h
A0000h] hash mismatch, opened image may refuse to boot" message on it, which the dumped bios does not have. I don't have the technical knowhow to calculate and patch in a new hash
https://www.badcaps.net/forum/troubl...40#post3345540Hi, I have used the search function copiously, and tried to follow a few leads in regards to getting a beep code of 0285, TCG-compliant functionality-related error (might be the TPM initialization failure). I've tried disabling TPM through powershell, tried autopatch script several times, and each time I try and boot with the modified BIOS I get a 0285 beep code. Using the dumped bios works fine. Any tips or knowhow on how to fix this? In UEFITool I found that the patched bios has a "FfsParser::checkProtectedRanges: Phoenix protected range [970000h
A0000h] hash mismatch, opened image may refuse to boot" message on it, which the dumped bios does not have. I don't have the technical knowhow to calculate and patch in a new hashComment
Many thanksComment
So I tried following the guide, but hit an immediate roadblock. The hash range 970000h: DA0000h doesn't match with the hash ranges in the security tab in UEFITool:
Code:FfsParser::checkProtectedRanges: Phoenix protected range [970000h: DA0000h] hash mismatch, opened image may refuse to boot
Unless I'm missing something from the tutorial?Code:Phoenix hash file found at base 00F88018h Protected ranges: RelativeOffset: 000A0000h Size: D0000h Hash: 873294B3EBBB3329BBA6ABED75392C98891C38BAF1A934FD01B45132EE4162AD RelativeOffset: 00170000h Size: 430000h Hash: F346D4820EAC0C54FF7B7D342BBEDC1773C839936B53F366B50CE7CC92DEF45B RelativeOffset: 005A0000h Size: 40000h Hash: B8B7D897008E232E13A2982BA212ED9F7DE467424B2D4BCB266A032E0A64F13A RelativeOffset: 005E0000h Size: 10000h Hash: 34669869FF876E3118FE418D5359ECB71CC02B2132BD6F68CE12C406AA4AF6F0
[QUOTE=Maxpower3;n3465640][QUOTE=Tokeri;n3465637]
BIOS in attachment (unmodified)
serial number PF-1QP25J
Type 20L6
[QUOTE=Tokeri;n3465647][QUOTE=Maxpower3;n3465640]
try
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
