macbook air a1466 efi lock
  • alihomee
    • Dec 2012
    • 1575
    • malaysia
    need to remove efi password from this file
    • 20873
    Re: macbook air a1466 efi lock
    Search for SVS with a hex editor - https://www.youtube.com/watch?v=KCl6Iu8fSSI .Most hex editors have a file compare function, use it to compare 2 files, one with a password and one without, you`ll see the differences then you can try it yourself.
    • alihomee
      • Dec 2012
      • 1575
      • malaysia
      i tried it but failed.....need some directions to do that
      • peste
        • 12786
        • ROMANIA
        all you have to do is watch the video ... here is the bios ...
        • AppleFixIndia
          • Aug 2020
          • india
          Please Remove Efi From This File
          • peste
            • 12786
            • ROMANIA
            try..
            • Dolapo1608
              • Sep 2022
              • 20
              • Nigeria
              Originally posted by peste
              try..
              Is the password removed here already?
              • peste
                • 12786
                • ROMANIA
                I think so..
                • laptopcenter
                  • Mar 2019
                  • 90
                  • haifa
                  A1466 emc 2559
                  Please unlock this bios
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Re: A1466 emc 2559
                    Unlocked:
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • SaSuKe84
                      • Jul 2024
                      • mexico
                      A1466 EMC3178 winbond 25Q64FVIQ bios lock
                    • envym
                      by envym
                      Hi everyone!
                      06-27-2025, 08:54 AM
                    • psdavid65
                      Macbook Air A1466 820-3437-B Booting Problem
                      by psdavid65
                      I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                      06-20-2024, 12:27 AM
                    • echothegamer
                      Macbook A1466 dies when charger disconnected
                      by echothegamer
                      Hello all,
                      Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                      Details:
                      Macbook 13' A1466
                      Board (820-3209-A)
                      Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                      Pictures below of Boardview and schematic...
                      I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                      It's an older model and it is very likely that battery has become...
                      10-28-2023, 12:00 PM
                    • kenzo2
                      Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                      by kenzo2
                      I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                      I need dump file MACBOOK PRO A2159
                      TSB4232(256)
                      TSB4229(256)
                      Thanks​
                      01-11-2025, 04:18 AM
                    • dbuergi
                      Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                      by dbuergi
                      i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                      Any ideas where to look?...
                      11-07-2024, 10:57 AM
