macbook air a1466 efi lock
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    need to remove efi password from this file
    • 22030
    Re: macbook air a1466 efi lock
    Search for SVS with a hex editor - https://www.youtube.com/watch?v=KCl6Iu8fSSI .Most hex editors have a file compare function, use it to compare 2 files, one with a password and one without, you`ll see the differences then you can try it yourself.
    • alihomee
      • Dec 2012
      • 1594
      • malaysia
      i tried it but failed.....need some directions to do that
      • peste
        • Dec 2016
        • 13691
        • ROMANIA
        all you have to do is watch the video ... here is the bios ...
        • AppleFixIndia
          • Aug 2020
          • india
          Please Remove Efi From This File
          • peste
            • Dec 2016
            • 13691
            • ROMANIA
            try..
            • Dolapo1608
              • Sep 2022
              • 20
              • Nigeria
              Originally posted by peste
              try..
              Is the password removed here already?
              • peste
                • Dec 2016
                • 13691
                • ROMANIA
                I think so..
                • laptopcenter
                  • Mar 2019
                  • 90
                  • haifa
                  A1466 emc 2559
                  Please unlock this bios
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Re: A1466 emc 2559
                    Unlocked:
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • SaSuKe84
                      • Jul 2024
                      • mexico
                      A1466 EMC3178 winbond 25Q64FVIQ bios lock
                    • envym
                      MacBook Pro 2018 with Activation Lock
                      by envym
                      Hi everyone!
                      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                      06-27-2025, 08:54 AM
                    • psdavid65
                      Macbook Air A1466 820-3437-B Booting Problem
                      by psdavid65
                      I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                      06-20-2024, 12:27 AM
                    • m1ch43lzm
                      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                      by m1ch43lzm
                      Hi everyone
                      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                      There's also an extra OTP Secu.R...
                      09-06-2025, 05:47 PM
                    • echothegamer
                      Macbook A1466 dies when charger disconnected
                      by echothegamer
                      Hello all,
                      Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                      Details:
                      Macbook 13' A1466
                      Board (820-3209-A)
                      Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                      Pictures below of Boardview and schematic...
                      I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                      It's an older model and it is very likely that battery has become...
                      10-28-2023, 12:00 PM
                    • kenzo2
                      Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                      by kenzo2
                      I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                      I need dump file MACBOOK PRO A2159
                      TSB4232(256)
                      TSB4229(256)
                      Thanks​
                      01-11-2025, 04:18 AM
