Please clear me bios macbook air A1466 820-00165-A EMC2925
Every donation made will go towards server fees and maintenance costs. -
I Need Bios For MacBook Air A1466 820-00165 EMC2925 Serial : C1MSW058H3QK Clean MeAttached FilesComment
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Good morning.
My MacBook Air 2015, serial FVFT149XH3QD, PLATE 820.00165-A, EMC2925, has a physically damaged flash. I tried the files posted here, and they worked, however, the MacBook takes 20 seconds to turn on. Is there any solution for this problem? Than You !!!Comment
post the contents of the bios chip even if it is corrupted..Comment
Hey good evening, Im looking for someone to clean the BIOS as it got the lock,
Serial : FVFD7ASTJ1WK
Motherboard number : 820-00165-A
A1466 EMC 3178
Thank you....Comment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
there is no other solution..remove the chip from the blower board, read it with the programmer and post the content here..
If you can't read it, how are you going to write it?
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowComment
pls clear me...macbook air a1466 i just change cpu because it was shorted before, struckup on loading apple logo..SN:FVFWGYS2J1WKAttached FilesComment
by vienzenMacBook Air A1466 EMC2925 (820-00165-A) Shorted PP3V3_S0
1. Problem of macbook is No Display
2. Found shorted caps on c1212
3. After removing the shorted caps (c1212) the reading in the c1212 pin1 is .003 in diode mode test, still shorted.
4. Help me..... -
by psdavid65I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
by echothegamerHello all,
Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
Details:
Macbook 13' A1466
Board (820-3209-A)
Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
Pictures below of Boardview and schematic...
I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
It's an older model and it is very likely that battery has become... -
by dbuergiHi all,
i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
Any ideas where to look?... -
by Sergio KubCould someone help me?
I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
Could it be the BIOS? - Loading...
