toshiba sat dablidmb8e0 rev e : no start
  • poweron
    • May 2019
    • 371
    • italy
    hello, unfortunately I don't know the model of this notebook because the license plate is missing, when I insert the power connector the power and wifi LED lights up and it doesn't respond to the commands, I tried to program several bios files but it doesn't work, I measured on the U18 pins (chip bios), and the voltages are very low around 1volt instead of 3.2v removing the chip are normal, in this regard I wanted to ask a question: the bios chip is a gigadevice GD25B64BSIG if I put a W25Q64BSIG winbond are the same?
  • kadi144
    • Aug 2015
    • 690
    • algerie
    Re: toshiba sat dablidmb8e0 rev e : no start
    same and you can use a ic 1.8v
    you must have all voltage good before flashing bios
    your pc is Toshiba Satellite C55-B PSKTWV
    or L50t
    or toshiba l50 b DABLIDMB8E0 REV E
    i can send you a good bios
    • poweron
      • May 2019
      • 371
      • italy
      ok,tank you
      • poweron
        • May 2019
        • 371
        • italy
        can anyone tell me where is the backup battery? I can't find it
          • 22312
          Post your original bios backup .
          • poweron
            • May 2019
            • 371
            • italy
            this is the original file
            • peste
              • Dec 2016
              • 13931
              • ROMANIA
              try..
              • poweron
                • May 2019
                • 371
                • italy
                does not work
                  • 22312
                  try this one .
                  • poweron
                    • May 2019
                    • 371
                    • italy
                    it does not work .... I begin to think that in addition to the bios there is another problem, as I said in another section about this case and that is that on the pins 1-2-7-8 of the bios chip I measure 0 , 7v instead of 3,2v while when it is off I measure 0v, if I turn on again I measure 3,2v but the pc does not turn on, the voltage of 0,7v I discovered that it comes from PQ10 from pin4
                    • poweron
                      • May 2019
                      • 371
                      • italy
                      hello, I come back to this case because I found some serial numbers of this model and I wanted to try to find the bios for this model: satellite L50-B - 2EM psktne-021017do serial number: 1f145340c dablidmb8e0 rev-e
                      thank you
                      • wakamelo
                        • Nov 2014
                        • 3
                        • spain
                        Thanks ........
                        work in Satellit L50-B-23J
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • cr4zychriss
                          by cr4zychriss
                          • Rebrand: PC Specialist
                          11-14-2025, 04:04 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • istvanszasz99
                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                          by istvanszasz99
                          Product Name: Razer Blade 15 (2022)
                          Product ID: RZ09-0421
                          Motherboard: CH580
                          BIOS Versions I work with: 2.02 & 2.06
                          Bios File Size: 32,768 KB
                          Dear Forum Readers!
                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                          !!! MY RAZER BLADE...
                          11-24-2025, 05:52 PM
