bias dump Aspire A315-55G
    • 22287
    Re: bias dump Aspire A315-55G
    Originally posted by Bartoloni
    here you are:
    Are there any part numbers or stickers on the motherboard ?
    • Ghamidi
      • Mar 2020
      • 306
      • France
      Originally posted by SMDFlea
      The bios updates can be extracted and edited,ZAW and ZAW2 are not the full bios,they are only bios updates at 13MB .Ive seen a few rev G dumps on the net and they`re only 8MB ,so i don`t know either ?
      i extraced 13Mo from exe file + 3Mo header acer bios from other backup
      • Bartoloni
        • Jul 2018
        • 140
        • Italy
        the eprom is a Winbond 128 ... btw now when the pc starts ( 24 seconds on warming up and 3 minutes to load windows ) there is the Intel Management Engine (on drivers) with an error.. this maybe can be a CLEAN ME issue?
        DA0ZAWMB8G0 rev G
        P.S. the flashed one is reporting the 1.12 release of the bios.. and after that i flashed with official tool to 1.17... and now i'm trying to flash to 1.18 ( that is the last one) .. just to be sure that BIOS and ENE will be at equal version of ME
        • Bartoloni
          • Jul 2018
          • 140
          • Italy
          these are the 2 driver (also the 3D video card without any driver)
          that become not working.
            • 22287
            Try this bios .
            • Bartoloni
              • Jul 2018
              • 140
              • Italy
              #26
              SMDFlea you are a GENIUS! this BIOS is perfectly working on the A315-55G board release G !!!
              P.S. the FAN is very loud, seems spinnig at maximum speed after a while.. thermal compount was just replaced ... i saw that the BIOS version is the 1.18
              P.P.S. after a while i pressed a switch (reset for freezed super-io chip) on the board... after that the fan is no more working at full speed... the CPU is an i5 10th with a turbo mode of +4ghz (!!!) 8 threads... a beast.
                • 22287
                I`m no genius. I used the bios from this thread,post #8 https://www.badcaps.net/forum/showthread.php?t=89632 .I cleaned the ME firmware .Clean the heatsink fins,and check if the fans metal cover is removable,lift the fan off the spindle,if it will lift with no force and put a drop of sewing machine or other light oil on the spindle.
                • Bartoloni
                  • Jul 2018
                  • 140
                  • Italy
                  #28
                  OMG never seen this thread
                  the fan is perfectly cleaned, the laptop has 1000 hours of use. the noise was for the extrtemely high rotation of the fan.
                  btw, thank you again
                  • micromag
                    • Jan 2021
                    • Romania
                    #29
                    Hey, guys! looking for the bios bin from aspire 315-55G-73N2, S/N:NXHEDEX02F936047557600. Can anyone help me?
                    • peste
                      • Dec 2016
                      • 13924
                      • ROMANIA
                      #30
                      post the bios backup.
                      • mberbouch
                        • May 2014
                        • 109
                        • Morocco
                        #31
                        Try this bios .
                        Worked for me too thanks.
                        • salawayon
                          • Nov 2012
                          • 578
                          • philippines
                          #32
                          i attached my with no display problem.. maybe someone could repair my dump..
                          i tried already a posted backup and it's working but i want to restore the original DMI/winkey data..
                          board info:
                          DA0ZAWMB8G0 REV: G
                          Thanks...
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12441
                            #33
                            board info:
                            DA0ZAWMB8G0 REV: G
                            Thanks...
                            ​https://www.badcaps.net/donate
                            • salawayon
                              • Nov 2012
                              • 578
                              • philippines
                              #34
                              tried but not working (still no display)
                              • salawayon
                                • Nov 2012
                                • 578
                                • philippines
                                #35
                                got it working for now after 3 tries to repair the original dump via fit... thank you
                                • Marc97
                                  • Jan 2016
                                  • 189
                                  • Phillipines
                                  #36
                                  Originally posted by Ghamidi
                                  but is not same motherboard
                                  this one is the good 1,,, thank you
                                  • jakeo22
                                    • Aug 2019
                                    • philipines
                                    #37
                                    it worked thank you , my board number is DA0ZAWMB8G0 REV: G
                                    • balobi
                                      • Jan 2015
                                      • 88
                                      • phillippines
                                      #38
                                      please help. i try some of the files above. some are working but can detect m.2 slot and also can't proceed on reformat process.
                                      acer A315-55g-5851
                                      SNID: 01308554676
                                      original bios attached issue no display.
                                        ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-12-2024, 03:36 PM
                                        ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-12-2024, 03:30 PM
                                        ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        ACER Aspire Aspire TC-885 Aspire TC i7-8700 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire TC-885 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-885 boardview and Aspire Aspire TC-885 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-12-2024, 03:28 PM
                                        ACER Aspire Aspire Revo R3600 Aspire 230 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire Revo R3600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire Revo R3600 boardview and Aspire Aspire Revo R3600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
