acer WCBT101X MB V1.0 bios request
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi I have this unit that if you power on it will go automatic on its bios , i think its a bios problem
    • 22084
    Re: acer WCBT101X MB V1.0 bios request
    Post bios backup .
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      here sir
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        Originally posted by kalilinux25
        here sir
        Sir is there a good file for this file above
        • ebyte64
          Bios request for Acer P214-52-58CH
          by ebyte64
          Good day.
          I would like to request a bios for the following laptop?
          Model: Acer P214-52-58CH
          Model No: N19Q7
          S/N: NXVLHE0H11204BA27600
          SNID: 11201936276
          Symptoms: Laptop powers on but no picture on screen.
          I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
          09-25-2024, 05:59 AM
        • Wg188
          ACER Veriton Z4660G AIO bios help
          by Wg188
          I have an Acer veriton Z4660G all in one pc,
          Model: Z4660G-I5850H1 (VZ4660G_W)
          Need bios dump and schematic would save my life !
          to make a long story short I bought this all in one used
          with a broken lcd, with the objective of making a custom desktop out of it
          ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
          06-17-2023, 02:20 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
