lenovo IdeaPad S145 bios needed
  • Subhasish91
    • Sep 2023
    • 8
    • India
    #381
    Re: lenovo IdeaPad S145 bios needed
    Originally posted by hoaca388
    serial number ?
    sn pf146rwb
    • hoaca388
      Badcaps
      • Jan 2022
      • 11348
      • Viet Nam
      #382
      Originally posted by Subhasish91
      S/n pf146rwb
      S145-15IWL Laptop (ideapad) - Type 81MV
      • Subhasish91
        • Sep 2023
        • 8
        • India
        #383
        Still Same issue No Display
        • hoaca388
          Badcaps
          • Jan 2022
          • 11348
          • Viet Nam
          #384
          Move on to finding hardware problems
          • lokz
            • Oct 2023
            • Croatia
            #385
            Hello, can someone please help me in this case. I bought replacement board for s145-15iwl but seller from Aliexpress sent me s145-14iwl board.
            Laptop works, but not numeric pad and delete key. (Insert behaves as Delete).
            I understand why, because 14" model has compact keyboard with power button placed on "delete" key location.
            Since both models are covered by same BIOS on Lenovo website, I wonder how is differed which one is 14" and which one is 15" model? Is there some fixed part of BIOS where that is set in factory, or that can be hacked/tricked to work? Or you need to enter Product or MTM (because now is empty)
            I read about some BIOS advanced menu, but I found no way to access such menu on this board.
            Any help is appreciated, especially from people who have experience with this.
            • peste
              • Dec 2016
              • 12290
              • ROMANIA
              #386
              I don't think the bios is the problem... I think you have to change the keyboard too... if the boards are similar, from the socket on the motherboard and the I/O chip... (routes)....
              • illiantech
                • Oct 2023
                • venezuela
                #387
                Originally posted by CA50
                Thanks a lot. Can anyone please explain the what DMI offset means?
                Can I just burn the ROM chip with the downloaded image ?
                Did you manage to install it without the DMI?
                Hello, what does DMI mean?
                have bios in bin format of lenovo ideapad s145-15API (motherboard: GS440&GS540 NMC511 REV-1)
                  • 20411
                  The serial number,windows key.
                  If you`ve made a good backup you`ll find everything you need to make a new bios with your DMI at post 342
                  • Necklace
                    • Mar 2023
                    • Deutschland
                    #389
                    lenovo IdeaPad S145-15IWL bios needed
                    I need an updated Bios. Power LED is blinking. Attached the read out Bios.
                    Bios/EC Version: ASCN39WW
                    MTM: 81MV014QGE
                    Serial number: PF214HF1
                    Thanks a lot
                      • 20411
                      Re: lenovo IdeaPad S145-15IWL bios needed
                      MTM: 81MV014QGE
                      Thanks a lot
                      • Necklace
                        • Mar 2023
                        • Deutschland
                        #391
                        Already tasted. Continues to blink. Video was there before. Laptop is but always regularly rebooted so every 10 seconds. Battery charges normally without interruption. Could call Bios but after the 10 seconds always reboot the laptop. So no Biosupdate possible via Windows. Therefore tried to flash. Chip can be written normally and also read out again. But comes when writing verifity error at 00000022 or 00000042. Already tried different Bioschips when writing. Therefore, I thought I'm doing something wrong with the Bios bin creation.
                        Translated with www.********/Translator (free version)
                        Last edited by Vesko356; 10-07-2023, 12:05 PM. Reason: External advertising url removed.
                        • ehud0406
                          • Oct 2023
                          • Israel
                          #392
                          Thanks for the detailed guide!!! it helped me recover my Lenovo.
                          • Dominiks1980
                            • Nov 2023
                            • 14
                            • Polska
                            #393
                            Hello.
                            Lenovo S145-15API 81UT, gs440&gs540 nmc511 rev 1.0
                            The laptop's LED was flashing and it wouldn't boot. I uploaded the bios from the Internet and the laptop started up. Unfortunately, I can't cope with copying DMI to the new bios. Can anyone find the DMI in the old bios?
                            EDIT
                            sn PF1XDE5K
                              • 20411
                              Originally posted by Dominiks1980
                              Hello.
                              You must post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
                              Is the bios you attached the original one,the DMI is corrupt.Find another S145-15API bios in this thread to use with someone elses DMI in it (and the windows key),the laptop will work.If you want to change it try the U1 tool and Thinkpad config info utility - https://www.badcaps.net/forum/troubl...ls#post1622424
                              • Dominiks1980
                                • Nov 2023
                                • 14
                                • Polska
                                #395
                                I added the serial number to the post
                                The bios that I attached to the post is a bios downloaded from a laptop, I don't know if it is original. Searching for the serial number in the hex editor does not find it. Could this not be the original bios?
                                  • 20411
                                  The DMI is encrypted so you can`t see the serial in the bios.The Offsets are 1000 - 2FFF ,starts with the word LENV. Sorry i didn`t look at it more carefully earlier,it looked like it was empty but there is some code there.If you want to copy the DMI yourself you`ll find everything you need at post 342
                                  • Dominiks1980
                                    • Nov 2023
                                    • 14
                                    • Polska
                                    #397
                                    I already copied 1000 - 2FFF before adding the post, unfortunately it didn't help.
                                    • Dominiks1980
                                      • Nov 2023
                                      • 14
                                      • Polska
                                      #398
                                      In post 326:
                                      "The DMI and Key is at these offsets DMI 520000 - 5207FF , Key 62D000 - 62D03F​"
                                      Only it's not in my bios 5207FF​ and 62D03F
                                        • 20411
                                        In post 326:
                                        I edited my post ,its at post 342 now,that post used to be at 326 ,two threads might have been merged together. Anyway here`s your bios + DMI .If its not wiorking you can try older versions ,and if they don`t work you have a hardware problem
                                        • Dominiks1980
                                          • Nov 2023
                                          • 14
                                          • Polska
                                          #400
                                          The bios I added to the post does not work. This is the bios that was in the laptop. I searched the Internet and downloaded the BIOS which works. Now I want to experience DMI from the Bios that I added to the post, to the BIOS from the Internet that works.
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
                                            Lenovo IdeaPad S145 Notebook S Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...
                                            09-06-2024, 04:40 PM
                                            09-06-2024, 04:00 PM
                                            09-06-2024, 03:30 PM
