Fujitsu E752 BIOS Update failed, FAN Problem after recovery.
  • spechto
    • Dec 2019
    • 4
    Hello together,
    to update the BIOS from Windows was a bad idea, because after the restart the update process failed and the system was dead. By programming a recovery BIOS directly in the two chips, the system was alive again. But after that procedure, the CPU Fan of the system runs with nearly 100%, without having a hot cpu. Has anyone an idea, how can I reset this? I restored the BIOS default, removed the BIOS battery and tried some other BIOS-Images ...
    Martin
  • foulou0238
    • Mar 2014
    • 109
    • France
    Re: Fujitsu E752 BIOS Update failed, FAN Problem after recovery.
    hello
    you have to clean ME before flashing the system
    good luck
    • RAVI KARAN
      • May 2020
      • 54
      • INDIA
      upload you old dump...try once clean me//
      • spechto
        • Dec 2019
        • 4
        Thanks, that was the advice, I needed! Now, the fan is working silent again.
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • michelhadid
          Crelander DS16 Dual screen BIOS Update failed recovery with CH341A
          by michelhadid
          Hey guys. Michel here. I´m trying to recover a Crelander DS16 Laptop (i7 10750h dual screen laptop, ZENBOOK DUO Clone).
          Laptop lost power and failed a BIOS Flash mid flash with AFUWIN/DOS. I of course made a backup beforehand, however, i can´t flash with AFUWIN/DOS now since it doesn´t boot/post anymore (black screen, fans on). I´ve read the BIOS chip (W25Q80DVSIG) with a CH341A Programmer, but AFUWIN Bios backup is 12MBytes and the CH341 read is a 1Mbyte file. I have compared both files and tried changing some data around with a hex editor (used WinOls to compare and edit) but...
          10-30-2023, 06:09 PM
        • Zarithya
          Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
          by Zarithya
          I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
          11-02-2025, 06:26 AM
        • test.it
          Failed bios update on a Dell Precision 3650 Tower
          by test.it
          Can anyone help me with a failed bios update on a Dell Precision 3650 Tower, service tag G01WWM3. The reason for the error was a power failure during the update. System no longer boots, no POST....
          01-28-2025, 07:32 PM
        • survivalbloke
          MacBook Pro 13" Touchbar, model A1706 - Critical software update failed
          by survivalbloke
          This machine came in with a no power complaint after a liquid spill. The only damage I found was on the two USB-C boards, so I replaced those, and the machine charges and fires up. However, if the internal LCD is connected to the logic board, when it boots, I will get a critical update failed warning and the only options are to shut down or try again - it's a loop. I am able to start up fine in safe boot. If I disconnect the internal LCD, I am able to boot normally to the OS. The customer doesn't want to invest any more money beyond what I already charged. Unfortunately, based on what I...
          11-21-2025, 01:12 PM
