Bios dump request for Asus X554LA-XO496H X555LD Rev 2.0
  • Theworm
    • May 2020
    • 13
    • Italia
    Hi, I write here because I can't find a dump for my BIOS, if someone has a dump of [B] Asus X555LD Rev 2.0 X554LA-XO496H [/ B], can you share it with me?
    I have a CPU [B] Intel i3-4030U [/ B] I don't have a video card, I only have a video card integrated in the CPU, if you want more information about my motherboard ask and I will give you more information.
    [B] Thanks in advance [/ B]: crying:
    • 20984
    Re: Bios dump request for Asus X554LA-XO496H X555LD Rev 2.0
    Post your bios backup .
    • Theworm
      • May 2020
      • 13
      • Italia
      my backup and this I don't know if I did the backup well
      PS=I tried to flash the original file bin which in a post shared the dump bin x555ld rev 2.0 but when I turn on the pc it turns the fan but the screen is black
        • 20984
        Its not a full backup .Try again .
        • Theworm
          • May 2020
          • 13
          • Italia
          how can I recover the bios if I have no other backup or I no longer have the bios with the original data?
          i could try flashing this in bios and dump?
          Am I going to download the update from the official Asus website and then flash it in bios chips?
            • 20984
            Have you desoldered the chip or using a clip .
            • Theworm
              • May 2020
              • 13
              • Italia
              I had unsoldered the chip.
                • 20984
                What programmer ?
                • Theworm
                  • May 2020
                  • 13
                  • Italia
                  I used ch341A
                    • 20984
                    Try and read it again using ASProgrammer software - https://www.badcaps.net/forum/showpo...6&postcount=10
                    • Theworm
                      • May 2020
                      • 13
                      • Italia
                      ok i try with ASProgrammer.
                      here is my backup
                        • 20984
                        Try this bios .
                        • Theworm
                          • May 2020
                          • 13
                          • Italia
                          ok now i try
                          • Theworm
                            • May 2020
                            • 13
                            • Italia
                            Originally posted by SMDFlea
                            Try this bios .
                            i tried it won't turn on the pc
                              • 20984
                              Do you have any white/green stickers on the motherboard ,with the model number printed. X554LA ,X555LA or something else .
                              • Theworm
                                • May 2020
                                • 13
                                • Italia
                                the printed model and x554la-xo496h , motherboard x555ld main board rev 2.0 print white on green motherboard, on motherboard is x555-la print on stickers white
                                • Theworm
                                  • May 2020
                                  • 13
                                  • Italia
                                  what can I do?
                                    • 20984
                                    try .
                                    • Theworm
                                      • May 2020
                                      • 13
                                      • Italia
                                      try .
                                      now flash
                                      • Theworm
                                        • May 2020
                                        • 13
                                        • Italia
                                        try .
                                        I tried but it doesn't work, I turn on the PC and the fan turns and the screen remains black.
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          Today, 06:12 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Anchar777
                                          ASUS P1412CE need BIOS DUMP
                                          by Anchar777
                                          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                          06-26-2025, 03:39 AM
