Zs040 la-a993p rev:2.0 BIOS
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    need HP 14-r004TU LA-A993P ec bios
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    Re: HP 14-r004TU LA-A993P ec bios
    need ec bios
    • teqcom
      • Nov 2015
      • 311
      • malasyia
      need ec bis
      • khaahk
        • Dec 2013
        • 830
        • Estonia
        • teqcom
          • Nov 2015
          • 311
          • malasyia
          thx a lot
          • Devendra Parihar
            • Jul 2016
            • India
            pz provide HP 14-r004TU LA-A993p Bios
            • rafsad ck
              • Apr 2016
              • 22
              • kuwait
              Help I NEED Hp240 g3 BIOS
              Hp240 g3
              bord id: Zs040 la-a993p
              ver :1.0
              • cyberhack
                • Feb 2013
                • 466
                • Uk
                Re: Help I NEED BIOS
                Here and can you let us know if it works
                • rafsad ck
                  • Apr 2016
                  • 22
                  • kuwait
                  thangs bro
                  • subroto
                    • Oct 2015
                    • 230
                    • Bangladesh
                    Help I need HP 240 G4 bios. Please.....
                    • SanWilliams
                      • Jun 2016
                      • 15
                      • peru
                      hola
                      • String2016
                        • Nov 2015
                        • 2242
                        • philippines
                        hp 14 r025tx not booting
                        Hi friends, i need help on this HP 14-r025tx board id:Zs040 la-a993p REV 1.0.
                        I have attached the original dump can someone clean the ME REGION for this Ill try to flash the bios with clean me, because i already flashed i got here in this foru m but still the same issue.The problem if you go to bios menu laptop not shutting down and restarting but when you install the hard drive it turns on and then restarts.I tried also plugged in usb flash drive with tried os install it does not boots up it keeps restarting, but when both hard drive or usb flash drive not plugged in it boots and stays no hard disk detected.can someone help me please Laptop has I3 cpu and nvidia graphics
                        • String2016
                          • Nov 2015
                          • 2242
                          • philippines
                          Re: hp 14 r025tx not booting
                          need help please
                            • 22286
                            here,try this .clean ME .
                            • ala_borbe
                              aka Donald
                              • 1625
                              • Malta
                              here it is, your bios file, virgin form hp support, clean me
                              Im Back... sort of...
                              • String2016
                                • Nov 2015
                                • 2242
                                • philippines
                                thank you i will try and give feed back soon
                                • String2016
                                  • Nov 2015
                                  • 2242
                                  • philippines
                                  thanks alaborbe but still the same issue when booting to usb flash drive to install os it goes off then starts again.could it be the cpu or nvidia is the problem?please help
                                  • String2016
                                    • Nov 2015
                                    • 2242
                                    • philippines
                                    need help please
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Disable graphics and see if it makes any difference.
                                      • on/off
                                        • Oct 2016
                                        • 333
                                        • Indonesia
                                        Try replace the bios chip.
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product Name: Razer Blade 15 (2022)
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          BIOS Versions I work with: 2.02 & 2.06
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
