Need a clean ME for MacBook Air
  • crazeej
    • Jan 2019
    • 32
    • germany
    Hi, this is a Weird one.
    at first it had sometimes fanspin without chime backlight or usb activity. sometimes - RARELY
    tried a few me regions but nothing helped.
    Plz Help ...
    now i have fanspin one time, stops than starts again!
    no chime no backlight or image!
    usb ssd is lighting up but no cpu activity.
    however cpu vcore measured after the inductors 1.710Volts.
    Help plz. lost
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Need a clean ME for MacBook Air
    You haven't stated logic board model number.
    Try another confirmed working dump (even with EFI password and dirty ME region) first.
    • crazeej
      • Jan 2019
      • 32
      • germany
      820-00165 sorry.
      2015-2016
      • peste
        • 13920
        • ROMANIA
        Try...
        • crazeej
          • Jan 2019
          • 32
          • germany
          Originally posted by peste
          Try...
          no change but thank you very much PESTE!!!... meanwhile i tryed from my older 00165 board the efi... nothing.
          so can be closed because ther is another issue.
          thank you!!!
          • crazeej
            • Jan 2019
            • 32
            • germany
            Tahnk you piernov. i tried it. no post at all... just fanspin and vcore
            any suggestions where i should look? hmmm u1950 couldnt be the fault. sorry just digging in to this world since one year
            • saulini
              macbook air a1932 no display but can hear the battery chime
              by saulini
              Hello guys...
              I bought MacBook from a garage sale the owner told me that the MacBook was dead and it did not display nothing, at first I thought it was related to a t2 problem so I did the bride OS with my other MacBook I was able to revive it but it did display the apple logo but on the apple configurator the lock symbol was there upon further inspection the MacBook did make the chime sound every time I disconnected the power cable but still it did not show any display also the caps key was able to light up, with nothing else to do i remove the motherboard and found the following...
              09-08-2023, 09:47 PM
            • survivalbloke
              Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
              by survivalbloke
              Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
              06-14-2023, 11:45 AM
            • thuygsm
              Macbook pro A2159 EMC3301 no image, no CapsLocklight, only USB activity
              by thuygsm
              Hello! Please help with a strange disease that I have never encountered before.
              At first I got the following status:
              MacBook does not turn on. Current consumption is about 0.500-0.600A at 20V from USB-C.
              - no signs of rust, or spilled water
              - CPU gets hot, fan still spins, no Capslocks light
              then I cleaned it and I got the following video:
              - Cannot install software, and after a while I get a red screen and the whole thing freezes
              Macbook Pro A2159 / Bệnh lạ
              07-28-2025, 11:35 AM
            • Comp_Pro
              Macbook Air 820-00165 Static Chime Sound
              by Comp_Pro
              Hello all,
              I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
              11-02-2023, 03:23 PM
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
