Lenovo 13 Gen2 - SVP Removal Request
  • ktheed
    • Mar 2020
    • 6
    Hello to all,
    Please can someone remove SVP from this Lenovo 13 Gen2 or advise me what to do, I have CH314a and IC CLIP.
    BIOS BIN is here:
    https://drive.google.com/open?id=1wT...gwM2Fto0NYFPzi
    Thank you
  • CraterM
    • Mar 2018
    • 180
    • Moldova
    Re: Lenovo 13 Gen2 - SVP Removal Request
    Originally posted by ktheed
    Hello to all,
    BIOS BIN is here:
    Thank you
    Try
    • ktheed
      • Mar 2020
      • 6
      Originally posted by CraterM
      Try
      Thank you...I tried to download your zip file but when opening WinRar states:
      The archive is either unknown format or damaged.
      Could you please re-upload..
      • peste
        • 13920
        • ROMANIA
        update winrar or use 7 zip..
        • ktheed
          • Mar 2020
          • 6
          Thank you.
          I have unzipped and programmed it and verified ok.
          It then displayed DXE Driver and Hardware ID, I pressed Enter, it said to press space, then press space again. it then said TPM changed and turnoff, i turned laptop off and then after reboot it displayed Time?date error and a CRC bad security checksum, pressed to enter bios and its hung on "Entering Setup . . . ."
          Am i meant to flash the original bios back as I have not done that yet ?
          • ktheed
            • Mar 2020
            • 6
            Your a star mate...it worked...thank you very much :-)
            • techcraze
              Lenovo 15ARH05 LCD whitelist removal request (Yes. display whitelists....)
              by techcraze
              Long story short. i am building a fully custom car radio. and want to use a extremely bright LCD.
              sadly the DGPU seems to be nonfunctional after i fixed the bios (fried voltage controller). so the Original HDMI port does not work.
              you can use a EDP TO HDMI adapter to add a HDMI port as replacement to the onboard EDP LCD connector,
              HOWEVER it turns out. lenovo enforces a LCD whitelist.
              this means you cannot upgrade the LCD despite matching EDP specs and voltages.
              If i connect a new screen directly to the system. only static shows....
              05-08-2025, 07:50 PM
            • Grafnus
              Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
              by Grafnus
              Hey there,
              first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
              So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
              Specs:
              • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
              • CPU, GPU, RAM work fine (not involved in the Problem)
              So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
              Now I noticed...
              08-06-2025, 11:54 AM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • maeson
              BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
              by maeson
              Hi dear Badcaps-Community,
              Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
              I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
              The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
              Lenovo Yoga L13 Gen 3 AMD:
              Lenovo Modell: Type 21BB
              Artikelnr.21BB006GGE
              Seriennummer: PW0A6207
              AMD Ryzen™ 5 PRO 5675U
              Memory 16 GB DDR4-3200MHz
              SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
              10-31-2025, 03:08 AM
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
