LA-6634P Bios
  • yunus_28
    • 6
    • giresun
    LA-6634P Bios
    la-6634p Rev:1.0 do you have any bios file ?
  • peste
    • 13915
    • ROMANIA
    Re: LA-6634P Bios
    post here the backup bios..
    • yunus_28
      • 6
      • giresun
      Re: LA-6634P Bios
      https://drive.google.com/open?id=1EK...A_hzH1DalJ1JmC
      my backed bios
      • peste
        • 13915
        • ROMANIA
        Re: LA-6634P Bios
        try...
        • yunus_28
          • 6
          • giresun
          Re: LA-6634P Bios
          bios run,thanks
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
