bios dump for TOSHIBA PORTEGE R30-A
  • Francisco.s
    • 686
    • Spain
    Hi, I need a bios dump for a TOSHIBA PORTEGE R30-A-17C.
    Thanks.
  • Francisco.s
    • 686
    • Spain
    Re: bios dump for TOSHIBA PORTEGE R30-A
    nobody has a good dump for this Toshiba?
    This is old dump:
    (problem with this dump is with intel graphics, it hung when intel driver is loaded)
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      This is old dump:
      That's not likely to be a bios issue .
        • 20884
        Bios with clean ME, for those who need it .
        • Francisco.s
          • 686
          • Spain
          Probably is not a bios issue, but it is something to test before changing cpu.
          It works ok in fail safe mode, also it works in normal mode without graphics driver active.
          The behavior is like a nec-tokin capacitor issue. (it boots well, but when it asks for windows password, goes black and freezes) (no BSOD)
          It is the same whit win-7 or win-10, when it freezes, drains about 1500 mA.
          In bios setup I have tested with core multiprocesing disabled, dynamic cpu frequency "always low" and intel turbo boost disabled.
          Memory ram ddr3L tested in both slots.
          Thanks for your answer.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            @Francisco.s, I faced this very same situation on HP 450 6050A2493101 MB where it works perfectly in safe mode,works well without intel hd driver in normal mode but screen goes blank at login screen when proper intel display driver installed. Unfortunately i could'nt fix it and was not able to find the reason behind such behaviour. Replacing the PCH also didnt helped either. As per some russian site, it has something to do DDR3 ram power but i could'nt locate it. Keep us posted if you are able to solve it.
            • Francisco.s
              • 686
              • Spain
              I have tested a new cpu and problem is solved.
              Thanks to all.
              • Bonzas
                • 471
                • Indonesia
                Anyone have 8 MB file ?
                or anyone can help repair this bios ?
                Here's my dump, problem is drop voltage
                • peste
                  • Dec 2016
                  • 12792
                  • ROMANIA
                  try..
                  • Bonzas
                    • 471
                    • Indonesia
                    Originally posted by peste
                    try..
                    i'll try tonight and give result
                    • Bonzas
                      • 471
                      • Indonesia
                      try..
                      tried
                      Result : power seem OK with this bios, but still no display.
                      when i try combine my backup and your build ( only change me region from your)
                      mb won't turn on
                      • jhuztine2881
                        • 34
                        • Philippines
                        Good Day to all...
                        Anyone can remove the password for this bios bin?
                          • 20884
                          Originally posted by jhuztine2881
                          Good Day to all...
                          The password is stored in the SMSC MEC chip,not the bios. The only way to remove it is by challenge-response code,or by changing the MEC chip from a donor board that has no password.
                          • Zazaku
                            • 16
                            • Indonesia
                            I need this BIOS 16MB for laptop Toshiba portege R30-A Series PART : PT341N
                            THANK YOU
                            • peste
                              • Dec 2016
                              • 12792
                              • ROMANIA
                              THANK YOU
                              post the backup of the bios
                              • yahya85
                                • Jan 2021
                                • 17
                                • surabaya
                                Hi, I need a bios for a TOSHIBA PORTEGE R30-A, code board FASRSY2 A3809A.
                                trouble is no display
                                this my old bios
                                • particlesolo
                                  • Apr 2020
                                  • 12
                                  • indonesia
                                  excuse me, my bios was no display / no capslock at usb keyboard,, kode board is FASRSY2 A3809A
                                  16MB FILE
                                  PORTEGE R30-A SERIES
                                  PT343N-IL7072
                                  PR734MAACR7AD71
                                  may someone help me check / repair this file...
                                  the unit is auto on when 19v go there
                                  all PL may get their voltage
                                  amperage 450mA board only with 2 rams
                                  processor get warm
                                  not yet change processor
                                  sorry for bad english im from indonesia
                                  • mod8082
                                    • Nov 2011
                                    • 6
                                    try..
                                    Thanks, This is perfect bios
                                    • rex98
                                      • Feb 2023
                                      • 1278
                                      • Mandaue CEBU, Philippines
                                      i also have same probem and same model.
                                      • b@w
                                        • Mar 2020
                                        • 33
                                        • ind
                                        try..
                                        THANKS Peste....its work for me...
                                          Toshiba Portege Portege Z30-C-1CV Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Portege Z30-C-1CV Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Portege Z30-C-1CV boardview and Portege Z30-C-1CV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:33 AM
                                          Toshiba Portege Portege X20W-D-11N Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Portege X20W-D-11N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Portege X20W-D-11N boardview and Portege X20W-D-11N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:40 AM
                                          Toshiba Portege Portege X30-D-10V Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Portege X30-D-10V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Portege X30-D-10V boardview and Portege X30-D-10V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
