HP ProBook 650 G1 Bios Locked
  • Bybit
    • Feb 2020
    • Netherlands
    Hi there,
    can someone help me to remove the administrator password that is on the bios of my HP ProBook 650 G1? I've created a dump file of it.
    Any help would be greatly appreciated!
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: HP ProBook 650 G1 Bios Locked
    Originally posted by Bybit
    Hi there,
    Deleted.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Bybit
      • Feb 2020
      • Netherlands
      Thanx for the file but can you also tell me how to install this unlocked file?
      I tried recovering the bios with a flashdrive (fat32 with the .rom file on it) en holding the windows and b keys when powering on the laptop. Nothing appears on the screen but the cap lock led is blinking and the fans run at full speed..
      How should I install the rom? :p
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Stop right there.
        What bios recovery, fat32 and bs like that. I just can't believe!
        If you want to do something but you don't know how ask first, no do your homework and then ask!
        So long story short, buy a programmer first - the chipset one is ch341a (10 bucks or even chipper from ali), then read how to use it and we can talk later.
        • Bybit
          • Feb 2020
          • Netherlands
          Haha thnx for sending me on the right direction. I'll do some research in programming the chip
          • marez
            • Sep 2016
            • Slovenija
            Hi:
            I have programmer ch341a, but one problem. Programmer dont recognize bios chip. Do i need to remove chip from motherboard
            • peste
              • 12859
              • ROMANIA
              you must remove the chip from the motherboard, read it with the programmer and make a copy of the original bios, check with hexedit before writing the chip with the new bios.
              • mhd_mahad
                • Jun 2016
                • 59
                • egypt
                I NEED HELP REMOVEING ADMINISTRATOR PASSWORD
                I TRIED HP UNLOCKER.EXE BUT SAME PROBLEM
                SERIAL: 2CE34924TD
                THANKS IN ADVANCE
                  SMDFlea commented
                  Editing a comment
                  is your caps lock stuck on - you should ask for a solution to this?
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
              • maanee11
                Help to get Lenovo BIOS bin file for Thinkpad T560
                by maanee11
                Hello Everyone,
                I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                05-15-2022, 11:59 AM
              • Sebastian Codrean
                BIOS file for ASUS F542UN laptop
                by Sebastian Codrean
                Hello to all of you! I need help with a BIOS file.
                The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                02-20-2025, 10:25 AM
              • Fr33man
                BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                by Fr33man
                I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                *Novo button power on
                *Disconnected internal battery...
                09-23-2024, 01:16 PM
