Asus x441UV rev 2.1 bios need to fix
  • n1ghtw1ng
    • Feb 2017
    • 12
    • Philippines
    any bios file for this model?
  • eikspaj
    N1NJ4W4RR10R
    • Mar 2015
    • 135
    • Philippines
    Re: Asus X441UV Bios
    upload your dump
    There are 10 types of people in the world. Those that understand binary and those that don't.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      I need help can someone fix this bios please! Attached is the original backup file can someone fix this please thanks
      • peste
        • Dec 2016
        • 13656
        • ROMANIA
        Re: Asus x441UV rev 2.1 bios need to fix
        try..
        • rulya56
          • Feb 2016
          • Украина
          dump
          • Motherboard Repairs
            • May 2019
            • 63
            • United Kingdom
            Originally posted by rulya56
            dump
            Try and test file and let me know.
            • spike888ph
              • Jun 2015
              • 31
              • Philippines
              this bios saved my day. thank you from the Philippines
              Originally posted by peste
              try..
              • djharold
                • Aug 2015
                • 246
                • COLOMBIA
                thanks for this
                • mohd1234
                  • Oct 2020
                  • 6
                  • Singapore
                  Thank you. It has helped me.
                  • mohd1234
                    • Oct 2020
                    • 6
                    • Singapore
                    Could you also assist to help me fix my BIOS?
                    I have attached the BIOS which I read from the chip.
                    My laptop is X441UV-GA070T
                    My motherboard is X441UV Rev2.1
                    Appreciate your help!
                    • peste
                      • Dec 2016
                      • 13656
                      • ROMANIA
                      try..
                      • mohd1234
                        • Oct 2020
                        • 6
                        • Singapore
                        try..
                        Sorry, may I ask if this is a generic one OR a repaired one from my BIOS?
                        • peste
                          • Dec 2016
                          • 13656
                          • ROMANIA
                          I named it the way I did it..from your original combined with the update on the Asus website and the ME region was cleaned ..
                          • mohd1234
                            • Oct 2020
                            • 6
                            • Singapore
                            Thank you very much it is working now
                            But I am worried about something. The Asus BIOS that should be used is X441UV but the one you gave was X441UVK. I have attached the Asus BIOS for X441UV.
                            Is there any difference?
                            • peste
                              • Dec 2016
                              • 13656
                              • ROMANIA
                              you don't have to worry..your bios are x441UVK exactly what you need ...
                              • mohd1234
                                • Oct 2020
                                • 6
                                • Singapore
                                That is great. Thank you once again!
                                • vougheart
                                  • Jul 2020
                                  • 65
                                  • philippines
                                  try..
                                  thank you so much sir i works 100% on my no display case
                                  • giya
                                    • Apr 2020
                                    • 50
                                    • indonesia
                                    try..
                                    this bios good and work for me. thanks master peste
                                    • Macias
                                      • Nov 2019
                                      • 83
                                      • Ecuador
                                      • drewpcfix
                                        • Feb 2021
                                        • 13
                                        • philippines
                                        my x441uv rev.2 hdd not detected issue ANY SOLUTION ITRIED YOUR SHARED BIOS BUT NOT WORK FOR MY CASE
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • caglarec2268
                                          Asus X515EA Bios File Please
                                          by caglarec2268
                                          merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                          Now "please follow the steps below to recover your bios" text remains on the screen
                                          I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                          laptop model x515ea-bq945w
                                          s/n: R4N0CV02K527148
                                          CN:HWFB
                                          Board model; ASUS X415EA R7.0
                                          bios chip: GD25Q128...
                                          11-27-2024, 03:51 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
