SPIN314-51 bios password request
  • bradastu
    • Feb 2020
    • 7
    • Thailand
    Any chance of a bios password for SPIN314-51?
    1906956639
    • 21173
    Re: SPIN314-51 bios password request
    Post your bios backup .
    https://www.badcaps.net/forum/showthread.php?t=41797
    We can only help you if you post your bios backup.
    You can buy a cheap bios programmer to backup your bios and then post it here, or buy an unlock key on ebay,you have buyer protection on ebay.
    This ch341a programmer on aliexpress has everything you need to backup your bios:
    https://www.aliexpress.com/item/32895557449.html
    • bradastu
      • Feb 2020
      • 7
      • Thailand
      Thanks for the feedback. Can you point to a guide on backing up bios? Seem to be a lot of parts in the ch341a programmer on aliexpress, and there's probably no English guide.
      TIA
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        TIA
        >>> English guide <<<
        Become a Badcaps supporter
        Thanks to all supporters.​
        • bradastu
          • Feb 2020
          • 7
          • Thailand
          Thanks for all the info. I'm working through the English guide to bios backup. In the meantime, could you tell me if this kit is up to the task: https://shopee.co.th/CH341A-CH341-24...635.2181547010
          It's available locally and would be delivered fast, but seems to have fewer components than the one on aliexpress.
          Ebay vendors have told me they don't have a solution using a master code, so I'll have to dismantle the unit, it seems.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            There is no 1.8v (newer Acer models using 1.8v bios chip) adapter in this kit and the soic clip, so better use SMDFlea suggestion.
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
            • traxformania
              TONGFANG "GM7TG7P" Bios Password Problem?
              by traxformania
              I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
              But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
              I'm trying to reset my bios without success.
              I tried :
              -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
              11-15-2023, 07:32 AM
            • outsider
              Panasonic FZ-G1 MK5 - BIOS password returning
              by outsider
              Hello
              I removed the BIOS password thanks to the help of one of the friends of this forum.
              https://www.badcaps.net/forum/troubl...61#post3637661
              The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
              06-17-2025, 12:51 AM
            • RMDUiFT
              Should I buy a Lenovo Thinkpad E495 with bios password?
              by RMDUiFT
              Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
              I have a few questions:
              • If I would buy this laptop and have
              08-25-2024, 09:00 AM
            • Johnny h
              Asus M7600R BIOS Password request/removal
              by Johnny h
              I'm hoping someone can assist me.
              I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
              It still boots into Windows (boots from whatever SSD is installed but not from USB).
              The model number is M7600R and serial number is N8N0CX03H71131C.
              I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
              I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
              Code:
              tmNx\'=QJQ
              04-10-2024, 06:13 AM
