for Dell Inspiron 14- 7447
Need Bios Bin file Inspiron 14-7447
Tags: None
Re: Need Bios Bin file
Post your bios backup...what the motherboard?...model..etc.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs. -
Try this and leave feedback.Attached Filesif you find these attachements useful please consider making a small donation to the site
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
