Lenovo T450s Bios bricked
  • 530v8
    replied
    Re: Lenovo T450s Bios bricked
    Originally posted by Maxpower3
    find Guid (not expand ),select this and Ctrl+Shift+R.
    remplace .fbd patched with the same GUID.
    same with others fbd.
    After Ctrl+S,save to XXXpatched.rom
    thanks bro
  • Maxpower3
    replied
  • 530v8
    replied
    Find by GUID
    Thanks you are the best!
    Edit:
    Found my problem
    i expand the GUID string and replace there one string not the whole GUID Body
  • Maxpower3
    replied
    Find by GUID
  • 530v8
    replied
    Are both translateservice and Bootoption in the same offset?
    Means same sector when I search with CTRL+F and type that in?
  • 530v8
    replied
    check the original reading of your bios, read it several times and compare to be sure
    Thanks I will try it in 2 or 3 hours
  • Maxpower3
    replied
  • 530v8
    replied
    Yes of course ,but use this one
    Thanks will try it on other t450s
  • Maxpower3
    replied
    Originally posted by 530v8
    which files do you used?
    i have 3 files attached, worked with this
    Thanks for helping
  • 530v8
    replied
    0.26 me too,just patched bootoptions and translate ,only body
    Thanks for helping
  • Maxpower3
    replied
  • 530v8
    replied
    you have to press F1 to boot setup?? and nothing
    nothing happens it hangs with an _ sign
    Edit:
    try to flash t450s_clean dump back
    Where is my fault? Work with UEFITOOLS 0.26
  • Maxpower3
    replied
    backup bios t450s clean
  • 530v8
    replied
    oops, i patched the original which doesn't work right ??
    second dump boots up but hangs on thinkpad logo nothing happens
    any idea?
    CMOS battery and all other batteries are removed
    Edit:
    Worked after pressing F1 so need to flash back the clean dump or what to do next?
  • 530v8
    replied
    so first dump not worked
    only 5 beeps pause and 5 beeps
    trying 2. dump
  • 530v8
    replied
    Yeah right this original doens´t work
    but will try it again
  • Maxpower3
    replied
  • 530v8
    replied
    try
    no battery ,no cmos battery etc...
    pass setup 1234
    thanks will try it
  • Maxpower3
    replied
    thats an bios from forum that lights up the 450s
    the original dump does not showing anything and not booting anymore
    attached original dump
    try
    pass setup 1234
  • 530v8
    replied
    "T450s clean.rar"
    it's bios OK or bios patched ?
  • akwky
    by akwky
    Hi!
    04-14-2025, 01:56 PM
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • Nicola Bianchi
    Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
    by Nicola Bianchi
    Hello!
    A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
    No the machine power up, but it stuck in a recovery state and I can not do much.
    Lenovo X1 Nano Gen 1
    Type: 20UN - X021US
    S/N: R9 - 10W2D9
    I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
    So here I am to ask for help.
    I opened the laptop and I found a chip that may be the target, on it I've:
    Winbond 25R256...
    01-11-2025, 09:50 AM
  • q2v5
    Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
    by q2v5
    Lenovo T480s
    Model 20L8-S3TE00
    Board ET481-U10
    Chip MX25L12873F
    Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
    2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
    The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
    08-15-2024, 10:40 PM
  • grimacelord
    Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
    by grimacelord
    Hello there.
    I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
    History:
    1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
    I searched for this error online and discovered...
    03-15-2023, 03:29 PM
