Dell Precision 7510 7710
  • torsten099
    • Oct 2021
    • 10
    Re: Dell Precision 7510 7710
    I soldered enamelled wire on the flashrom pins, the end are leaded out of the laptop to a connector that I can connect to a raspberry pi for the programming via flashrom. The verify process is always valid, and the laptop is complete assembled with all its parts.
      • 20299
      Try a bios recovery, download the bios update then rename the exe to BIOS_IMG.rcv ,copy it to a flash drive and put it into one of the USB ports.Take the main battery out and charger,press and hold CTRL + ESC ,plug the charger in and see what happens.
      • torsten099
        • Oct 2021
        • 10
        This was one of my first actions before I decided to use the flashrom method.
          • 20299
          So, the first time you updated the bios it was from USB or through windows,did you use the USB only for the recovery ? What did you see on the screen during the update ,did it stop with an error message at some point
          • torsten099
            • Oct 2021
            • 10
            I run a ubuntu system on the laptop, so I used a usb stick to update the bios.
            Everthing rans without any errors. All flash processes were done, then the automatic reboot and from there on I have this issue.
            • torsten099
              • Oct 2021
              • 10
              After disconnecting the left side daughter board, the laptop starts different not more in a resetting loop. But still not correct. I think the bios update bricked the flashrom content of that board. Have someone more information?
              • torsten099
                • Oct 2021
                • 10
                A short update: My problem is solved. But only for me, not for the laptop. Because I decided to throw it into trash can, because of other new physical electrical errors. So I need no more help, thanks to all.
                • Andreasbest
                  • Aug 2014
                  • 1132
                  • Hellas ( Greece )
                  #48
                  Dell Precision 7510 BIOS integrity verification please
                  Hello!
                  Can someone please check if this dump from Dell 7510 is 100% valid and not corrupted?
                  I want to know if the BIOS chip is good or no.
                  Thank you!
                  • stanker19
                    • Jun 2017
                    • 14
                    • Việt Nam
                    #49
                    Re: Dell Precision 7510 BIOS integrity verification please
                    Originally posted by Andreasbest
                    Hello!
                    Thank you!
                    -Source bios not running eat 0.200A current hanging
                    • Andreasbest
                      • Aug 2014
                      • 1132
                      • Hellas ( Greece )
                      #50
                      So you think the bios is bad?
                      Also please tell me what LED sequence you get with it.
                        • 20299
                        Hello!
                        Thank you!
                        try this one
                        • Andreasbest
                          • Aug 2014
                          • 1132
                          • Hellas ( Greece )
                          #52
                          Originally posted by SMDFlea
                          try this one
                          Hello!
                          I have good BIOS, i just want to know if the one attached is good dump.
                          That's all.
                            • 20299
                            Hello!
                            That's all.
                            Well the ME firmware is initialised,which means its not clean and if you wanted to use it on another machine it should be cleaned first. The bios could be good or corrupt,it only takes 1 byte to be bad.Sometimes if it is badly corrupted its noticable just by scrolling through and looking at the code,but you wouldn`t notice a byte or two.The only real way to tell is to flash it and see what happens
                            • TheQuentincc
                              • Mar 2017
                              • 59
                              • France
                              #54
                              try this one
                              Hi, I had a corrupted bios on my 7710 (sometime the power button led would light up for 1 sec and sometime for like 5 sec and the keyboard would briefly light up, then shut down).
                              I flashed this dump on my 7710, it's now working apart from the Wifi (the card is fully working on a 7720 and the 7710 bios still recognize it's bluetooth capability when plugged), do you think it might be bios related ?
                              I updated the bios to 1.20.3 in case something else was messed up but it didn't fixed the issue, I also tried a 8265 and 3160 wifi card to no avail.
                              For the record, I attached my dump (corrupted bios).
                              Thanks you.
                              • lapfix
                                • Mar 2020
                                • 2564
                                • my workshop
                                #55
                                Thanks you.
                                Try this clean me
                                Your service tag !
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11152
                                  • Viet Nam
                                  #56
                                  Thanks you.
                                  Precision 7710
                                  Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
                                  • TheQuentincc
                                    • Mar 2017
                                    • 59
                                    • France
                                    #57
                                    Originally posted by lapfix
                                    Try this clean me
                                    Your service tag !
                                    Same issue as with the corrupted bios, no boot.
                                    Originally posted by hoaca388
                                    Precision 7710
                                    Again no boot but the power button led was up for like 30sec, then bootloop.
                                    My service tag is D9TD3G2, so base model without thunderbolt and without vpro.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11152
                                      • Viet Nam
                                      #58
                                      Try again.
                                      • TheQuentincc
                                        • Mar 2017
                                        • 59
                                        • France
                                        #59
                                        Try again.
                                        It still doesn't work, the power led light up for 2 sec, then shutdown and back on for more thant 30s and so on :/
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11152
                                          • Viet Nam
                                          #60
                                          You should find other problem, with bios, i can't do better.
                                            DELL Precision 7710 Mobile workstation 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 7710 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7710 boardview and 7710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                            09-06-2024, 12:25 PM
                                            DELL Precision T3630 Precision 3000 i7-8700 Specification for Upgrade or Repair
                                            This specification for the DELL Precision T3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3630 boardview and Precision T3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                            09-12-2024, 03:44 PM
                                            DELL Precision 3630 Precision i7-9700 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            DELL Precision 3440 Precision 3000 i7-10700 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 3440 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3440 boardview and Precision 3440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            DELL Precision 3630 Precision 3000 i7-9700 Specification for Upgrade or Repair
