hp 840 g6 6050A3022501-MB-A01
  • hoaca388
    replied
    Originally posted by babyboo092
    Hello there, I hope someone can help me with my dead BIOS that failed to start after an update. the machine does not power on even after pressing the power button . thank you!
    sn.2TK9500RN6
    HP EliteBook 840 G6 Notebook PC
  • babyboo092
    replied
    Originally posted by SMDFlea
    Read the password guide, try RCUnlocker - https://www.badcaps.net/forum/troubl...23#post1622423
    sn.2TK9500RN6
    replied
    Originally posted by alechs85
    Hello.
    HP EliteBook 840 G6 (14-in) Touch Laptop (HSN-I24C-4)
    Please remove the password from the BIOS
    serial number SCG0159CZF.
    Read MX25L25635E, W25Q128BV.​
  • alechs85
    replied
    Hello.
  • bert-bert
    replied
    Originally posted by hoaca388
    MAC : BC:E9:2F:E6:CA:B0
    Hey, this is great! Even though I had to flash the 32MB chip twice, probably because my soldering skills are not good enough, now it works perfectly! I did not need BCU nor MPM, it just boots with the correct information, even though it told me once that it has to recover the data because of a mismatch.
    hoaca388, you are the best, thanks a lot, and also thank you again danito for trying to help!
    Would you mind me asking how you produced these files? Have you handcrafted them in a hex editor, or do you have a tool for that?
  • hoaca388
    replied
    Originally posted by bert-bert
    in the meantime I tried to clear VSS2, but the laptop did not boot any more then.
    So I reflashed "New folder (2).rar" in 32MB and 16MB chip and now I am again in MPM, but the LAN Port does not work. I get an error in device manager for the Ethernet controller and cannot set the right MAC address in the BCU or in the BIOS.
    Does someone have a clue how to make the ethernet LAN port work?
    Thank you in advance!
  • bert-bert
    replied
  • Duvelhedz
    replied
    Originally posted by LBTT1121
    post S/N
    5CG952962K
  • LBTT1121
    replied
    Originally posted by Duvelhedz
    Looking to unlock mine and remove a "startup delay" if possible.
    Attached are both dumps.
    Thanks in advance :-)
    post S/N
  • Duvelhedz
    replied
  • bert-bert
    replied
    Originally posted by danito
    try
    Hey, this is great! A clean BIOS where I can enter the information with the Bios Config Utility!
    I now flashed the BIOS, and it boots. Then I entered the information in the Bios Config Utility, but somehow the MAC Address cannot be set. It always stayed at 00-04-80-00-40-00 in the BIOS. Probably because of a defective ME configuration this configuration was not possible. Dumb me, I locked the Manufacturer Programming Mode even though the MAC address does not match. When locking the MPM I entered the MAC Adress in the BIOS so the locking was possible. But on the Information page there is still not a valid MAC address. After locking MPM, I could fix the ME by performing a BIOS update.
    But now the LAN port does not work. What can I do? Is there a possibility to unlock MPM again, without having to reprogram both chips? Is the non-working LAN port even caused by a wrong configuration or is this an other error? Is it possible to do this with reprogramming only one chip? Shall I send the content of the 32MB Chip? Will this help?
    Will cleaning the VSS2 unlock MPM and help here?
    danito, thanks a ton, and for any further help, thank you in advance!
  • danito
    replied
    I have an EliteBook 840 G6. It had a bios password. Then I tried to read the 32MB BIOS chip, but thereby destroyed the content of this chip.
    In the meantime I have unsoldered 32MB and 16MB chip and tried to flash contents available here in the forum, but I did not succeed. The best that had happened was that I had a working laptop, but as soon as I restored the BIOS to factory default configuration the laptop died and never turned on again.
    I upload the defective 32MB BIOS and the 16MB chip content with password here.
    Would someone mind helping here?
    ProdID: 7KN34EA#ABD
    SN#: 5CG024BH8H
    try
  • bert-bert
    replied
    ProdID: 7KN34EA#ABD
    SN#: 5CG024BH8H
  • peste
    replied
    Originally posted by BRAHIIM07
    anyone help me. elitebook 840 G6
    CRESCENT 6050A3022501-MB-A01
    HELP ME I NEED PHOTO FOR BIOS SHIP 32MB
    and original dump bios PLEAS
    post S/N,post the contents of the bios chip even if it is corrupted..
  • BRAHIIM07
    replied
  • terrapigui
    replied
    Originally posted by terrapigui View Post
    hi, i need fix bios dump of HP Elitebook 840 G6. serial: 5CG0276GT1
    product: 4WG30AV
    thanks
    Archivos adjunt
    What tool do you use to backup bios ?​
    I extract the chip and read it with the rt809f programmer
  • hoaca388
    replied
    product: 4WG30AV
    thanks
    Archivos adjunt
    commented on 's reply
    Thread moved and merged.
  • terrapigui
    replied
    product: 4WG30AV
    thanks
    Archivos adjunt
  • EdwinTulcanaz
    replied
    Originally posted by EdwinTulcanaz
    I'm sorry, I have this error on the first screen and it doesn't do anything else, could you help me solve it?
    I attach my original files
    HP ELITEBOOK 840 G6
    SN:5CG02215SY
    Board number 6050A3022501-MB-A01(A1)
    Greetings, if you can help me please
