hp 840 g6 6050A3022501-MB-A01
follow these instructions.
First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.
use BCU permanently disable the absolute there.
here's your DMI info:
Serial Number: 5CG025F59C
Product Number: 4YD61AV
CT Number: PHWHB00WBDS7OK
Description: HP EliteBook 850 G6
build_id: 19WWCFCT601#SABA#DABA
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPfXgShKjhk8.72
MAC Address: BC-E9-2F-CC-55-46Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello,i need help, it's a locked laptop hp 840 g6, which after unlocking gives an endpoint security error, I've tried almost all files from the forum. it doesn't work, it throws an error, I'm sending you the original locked files. please unlock them, and remove the endpoint error.Attached Filesif you find these attachements useful please consider making a small donation to the site
Read the rules before posting
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
only flash this main do not touch the EC.Hello,i need help, it's a locked laptop hp 840 g6, which after unlocking gives an endpoint security error, I've tried almost all files from the forum. it doesn't work, it throws an error, I'm sending you the original locked files. please unlock them, and remove the endpoint error.
Serial Number: 5CG0338WNT
Product Number: 4WG30AV
CT Number: PHWGH00WBE3D13
Description: HP EliteBook 840 G6
build_id: 19WWCFCT601#SABD#DABD
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXhKhkjhk8.y8
MAC Address: 84-2A-FD-C7-EB-84Attached Filesif you find these attachements useful please consider making a small donation to the site
Good Day Masters! Anyone can remove computer trace on my BIOS Bin? Thanks in Advance
Model: HP 840 G6
Board: 6050A3022501-MB-A01
S/N: 5CG9341GFKAttached Filesif you find these attachements useful please consider making a small donation to the site
First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults and exit.
Use BCU to fill these DMI info. you can permanently disable absolute in BCU
Serial Number: 5CG9341GFK
Product Number: 7UA41UC#UUF
CT Number: PHWGH00WBCN7NX
BuildID: 19WWCFAT603#SUUF#DUUF
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
MAC Address : 04:0E:3C:40:56:41Attached Filesif you find these attachements useful please consider making a small donation to the site
SOme one help me fix this file. not detect ssd
board code: 6050A3022501-MB-A01
This no have serial numberAttached Filesif you find these attachements useful please consider making a small donation to the site
hereAttached Filesif you find these attachements useful please consider making a small donation to the site
again tryAttached Filesif you find these attachements useful please consider making a small donation to the site
hello friends i need remove password and clean me hp elitebook 840 g6
and i have this message
hp endpoint security controller problem
i need resolve this messageAttached Filesif you find these attachements useful please consider making a small donation to the site
hp endpoint security controller problemAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Hello Guys,
my HP 840 G6 did and automatic BIOS Update and then it failed somehow..
When i try to Power it ON the Caps Lock stays on the whole time and nothing other happens.
Here are my 2 Bios Dump Files (32MB Chip and 16MB Chip)
The 16MB file is corruptedAttached Filesif you find these attachements useful please consider making a small donation to the site
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
Channel: BIOS Requests ONLY!
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
by justice171Hi BadCaps team,
I’m asking for a bit of community help with a Proline notebook that’s stuck with a Power-ON (BIOS) password. The laptop has very limited info available and I suspect it may be a local (South African) Proline board. Thought I’d check here in case anyone has seen this one before.
What I have:- Model: Proline NoteBook V146GNK
- Board: SU_GN100_MB_V12_20231120A
- Serial: GN10Q12124205W1588
- Notes: 12V main board. Very little documentation available.
What I’d like to request:- Has anyone dealt with this Proline board before or seen matching BIOS/firmware
by fx1982Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
It's a 2024 Asus Zephyrus G16
GU605MV
SN: S2NRCX035924088
CN: AEDW
MFD: 2024-02 36M
BIOS VERSION: 315...-
- Loading...
