850 g5 6050a2945601-mb-a01 bios
    • 24616
    Originally posted by reformatt
    Not sure what the go is with this one. I had left it doing final Windows 11 updates, when I came back to it later had high fan spin and forcibly turned it off with power button. Not sure if this was a bad Windows F/W update or not. Now all I get is 7 orange blinks on the battery light when the power is applied either via barrel adaptor or USB-C. This doesn't seem to line up with anything in the manual. AFAIK, it was already on V1.31 BIOS which is supposed to be the latest.
    One other weird thing is it is flattening the BIOS battery after I just have replaced it but I think that is a side issue. Attached are the dumps for BIOS (U365) and EC (U366). S:N is 5CG8100CT2. BIOS looks ok in UEFI tool.
    Edit. Was checking the CMOS battery issue and found 12 ohms on P3V3_RTC and only .75V present. Usually I find these issues to be PCH related but there quite a few things on this rail.
    Edit 2: Bloody cap! I put 3V onto that rail and it finally went full short. Was C4766 (1uF 0201) just on the other side of the board from the CMOS battery connector. Now it starts up.
    Flash attached U365 ,flash original U366 back as-is.
    • reformatt
      • Feb 2020
      • 1745
      Thanks Flea. I had modified U366 with another dump prior to finding the leaky cap (thinking it was an EC update failure). Once the cap was replaced, the laptop booted up, however reported an Endpoint Security failure. I did try a downgrade to V1.30 to reflash but it bricked the machine. Restoring both my original dumps resolved that so messing with the EC bios you will get this problem.
      The primary fault was the leaky cap on P3V3_RTC pulling it down to 0.75V. It measured 12 ohms initially, but went full short when I injected 3V onto it.
      • bajticzek
        • Jan 2020
        • Czech Republic
        #43
        this Elitebook I bought was previously worked on. Symptoms included 5 short CapsLock blinks and fans on full speed. Core voltages were missing, I found rotten trace from VRM controller, repaired it and the laptop sprung back to life. The 5 blinks before booting persisted. I blame the content of Winbond flash as soldering on legs was visible and the content might be wrong. The correct serial number showed in BIOS, so I tried to do a BIOS update. The BIOS version was Q78 v01.07.00. It didn't accept newest update, so I tried the closest one to the old. I found v01.09.00. Content of the update was succesfully copied (progress bar finished), then error notification about the USB-C controller firmware being the same version as in the update file (which is fine), then reboot and infinite black screen with 5 blinks and fans on full speed. I tried various recovery procedures, none works. The laptop has the Sure Start feature.
        I uploaded current content of W25Q256JV flash memory.
        The serial number of laptop is 5CG9034328.
        Any help is appreciated.
        • peste
          peste commented
          Editing a comment
          post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • bajticzek
        • Jan 2020
        • Czech Republic
        #44
        Can anyone provide the correct (or my repaired) BIOS for this laptop, please?
        • xplodpg
          • Oct 2016
          • 50
          • Polska
          #45
          Hi. I need bios.
          Old bios is broken. Beep code- 2 long 2 short
          HP Elitebook 850 G5 6050a2945601-mb-a01
          SN: 5CG83131L9
          Prod. ID- 3JX13EA#BCM
          • danito
            • Jun 2016
            • 1817
            • N/A
            #46
            try
            • danito
              • Jun 2016
              • 1817
              • N/A
              #47
              Originally posted by xplodpg
              Hi. I need bios.
              SN: 5CG83131L9
              read again and post
              • xplodpg
                • Oct 2016
                • 50
                • Polska
                #48
                Originally posted by danito
                read again and post
                The laptop is in another repair shop. There was only this BIOS
                  • 24616
                  try these, flash both.
                  • xplodpg
                    • Oct 2016
                    • 50
                    • Polska
                    #50
                    Doesn't turn on. Power LED doesn't light up.
                    • Mierd
                      Learner
                      • Dec 2024
                      • 8
                      • Spain
                      #51
                      I have an HP EliteBook 850 G5 with an Intel i7 that is not starting due to what seems to be a BIOS issue.
                      At the beginning, the laptop was powering on, but it was showing some security-related alerts during startup/BIOS checks, which could simply be bypassed by pressing the Esc key. In any case, in an attempt to solve the issue, I dumped the BIOS and tried flashing a couple of BIOS files I found on this forum, but I couldn’t fix the problem.
                      Now, after rewriting the original BIOS, the laptop no longer powers on or shows any signs of life. The only thing I get is the Caps Lock and Num Lock LEDs blinking.
                      Could someone please help me with a repaired/clean BIOS file?
                      Model: HP EliteBook 850 G5
                      Serial Number: 5CG01046Q3
                      CPU: Intel i7 8th
                      Any help would be greatly appreciated. Thanks!
                      • Sparo
                        Quicksilver
                        • Jan 2022
                        • 4583
                        • M\A
                        • Anime, Edge Computing, Football, Snooker
                        #52
                        CPU: Intel i7 8th
                        Hi, Try this BIOS file and See if it works
                        HP EliteBook 850 G5 Notebook PC
                        BIOS Version: 01.31.00 Rev.A
                        Enjoying our forum? Subscribe to unlock extra perks!
                        >> Upgrade here <<
                        • Mierd
                          Learner
                          • Dec 2024
                          • 8
                          • Spain
                          #53
                          Hi! Thanks so much, really appreciate your help mate!!
                          I tried with the file you uploaded, but still nothing… I even bought a new BIOS chip, same exact model, just in case it was a physical issue — but no luck. I still only get the Caps Lock and Num Lock blinking. I even tried flashing the backup of the original BIOS, and now even that one gives the same result… 🙁 I must be doing something wrong somewhere.
                          Maybe something is misconfigured in the XGPro software I’m using?
                          Here’s a screenshot of the settings I currently have in the software.
                          I’m a bit lost at this point 😓
                          • Sparo
                            Quicksilver
                            • Jan 2022
                            • 4583
                            • M\A
                            #54
                            There's no special setup needed for XGecu. Just follow the usual process: Erase → Write → Verify
                            If the verification passes, the chip was written successfully. If not, try lowering the SPI clock frequency
                            That said, try flashing both the U365 and U366 chips with the files provided by SMDFlea (Post #'49)
                            Here's a link to Post #'49 to avoid any confusion > https://www.badcaps.net/forum/troubl...14#post3879014
                            >> Upgrade here <<
                            • Mierd
                              Mierd commented
                              Editing a comment
                              Hi again! Thanks a lot for all your help, mate!!
                              I finally managed to “solve” the issue I was having. It turned out that it wasn’t related to the BIOS programming after all. With a bit of patience and the help of a microscope, I realized that a tiny resistor next to the BIOS chip had moved slightly and was no longer making proper contact. I repaired it, and the laptop came back to life.
                              I’m still getting the security device errors, though, so I’m going to create a new post and upload the dumps from both chips, as I believe the EC may be the one causing these errors.
                              I still don’t have enough knowledge or experience to create my own clean BIOS binaries from the original vendor files, but I’m trying to learn. I have all the tools I need… just not the knowledge yet! 😅
                              Any recommendations or guidance would be more than welcome. It’s a bit confusing when you’re just starting out and trying to figure out the correct process, what the first step should be, then the second, and so on. I’d really like to understand the proper workflow rather than just relying on BIOS files that other people have already cleaned or repaired. I also don’t want to keep bothering people every time I run into this kind of issue, so I’d really like to learn how to handle these things properly myself.
                            • Sparo
                              Sparo commented
                              Editing a comment
                              I'm glad you were able to figure it out and sort the issue yourself. Yes, this can happen when using a hot air gun (the airflow can accidentally move or knock off small resistors or other components in the soldering area) You'll get more familiar with the process over time. I recommend watching some YouTube videos for soldering tips and techniques, but practice is the key to improving
                              Also, regarding your request and since I actually never copy anyone else's files. I always create my own from scratch, even when helping dozens of users. I see you already posted your BIOS and EC files. I'll check your latest post and try to guide you through the process or point you to a thread that explains the procedure. See you there!
                          • M_O_B
                            • Jan 2026
                            • 27
                            hi, please help remove admin password.
                            RCUNLOCKER could not fix it.
                            S/N: 5CG8511CN0
                            • Sparo
                              Quicksilver
                              • Jan 2022
                              • 4583
                              • M\A
                              #56
                              Hi, You have to post the Serial Number with every single request (As per the Forum rules)
                              > RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - Badcaps
                              >> Upgrade here <<
                              • M_O_B
                                • Jan 2026
                                • 27
                                I JUST UPLOADED THE SERIAL NUMBER.
                                THANK YOU SIR
                                • Sparo
                                  Quicksilver
                                  • Jan 2022
                                  • 4583
                                  • M\A
                                  #58
                                  THANK YOU SIR
                                  S/N: 5CG8511CN0
                                  Read again your EC chip, and Post the MAIN BIOS chip as well
                                  >> Upgrade here <<
                                  • M_O_B
                                    • Jan 2026
                                    • 27
                                    here are the ec and main files.
                                    • Sparo
                                      Quicksilver
                                      • Jan 2022
                                      • 4583
                                      • M\A
                                      #60
                                      Write only the EC chip first. If somehow it still doesn't work, then flash both
                                      P.S: In your unlock attempt, you deleted both NvramActiveRegions. Only the first one needs to go
                                      >> Upgrade here <<
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • Hayo2020
                                        Request: Clevo V170PNJQ-D02 BIOS Dump (Captiva I72-555) – 32MB
                                        by Hayo2020
                                        I am looking for a working BIOS dump for a Clevo
                                        V170PNJQ-D02 motherboard (P/N: 6-77-V170PNJQ-D02-3C#10).
                                        The laptop is a Captiva Advanced Gaming 172-555 (i5-12500H / RTX 3050). The original BIOS flash failed, and unfortunately, the original SPI chip was damaged during removal, so | cannot read a backup of the corrupted file.
                                        • Board: Clevo V170PNJQ-D02
                                        • BIOS Chip: GigaDevice GD25B256E (32MB / 256Mbit)
                                        • Vendor: InsydeH2O
                                        A clean BIOS dump or a working dump with a clean
                                        ME region would be greatly appreciated!
                                        08-04-2026, 02:51 PM
                                      • cr4zychriss
                                        by cr4zychriss
                                        • Rebrand: PC Specialist
                                        11-14-2025, 04:04 PM
                                      • bharataus
                                        Acer Nitro 5 N22C1 (AN515-58-93JE) – BIOS Fix Needed (Winbond 25Q256JVEQ 32MB)
                                        by bharataus
                                        I’m working on an Acer Nitro 5 and need assistance with a BIOS repair.
                                        Device Details:
                                        Model: Acer Nitro 5 N22C1
                                        Variant: AN515-58-93JE
                                        BIOS Chip: Winbond 25Q256JVEQ (32MB)
                                        Serial Number: NHQHYSAA003245032C63400
                                        SNID: 24501299834
                                        MFG Date: 2022/11/12
                                        Issue:
                                        The laptop is not functioning properly, and I suspect a corrupted BIOS.
                                        What I Have:
                                        Original BIOS dump (attached)
                                        Photos of the device...
                                        04-22-2026, 12:23 AM
                                      • Arzigol
                                        Acer Nitro Lite 16 NL16-71G (V1.19) - BIOS Unlock / Advanced Menu / CFG Lock
                                        by Arzigol
                                        Hello everyone!
                                        I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
                                        Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
                                        Laptop Information
                                        Model:
                                        Motherboard:
                                        CTE_NB_NL160P1G_RTH (NB6807C)
                                        CPU:
                                        Intel...
                                        07-12-2026, 02:27 AM
