lenovo B590 problem about battery/ bios also
  • kalilinux25
    • Mar 2018
    • 2084
    • ZAMBOANGA SIBUGAY
    I have a LENOVO B590 Ive replace it a new battery , but it says the battery installed is not supported by this system wand will not charge.Please replace the battery with the correct lenovo battery for this system.,
    If someone has this kind of problem, Ive read some forum they said its a bios issue that u need to upgrade its bios ..
    • 20689
    Re: lenovo problem about battery/ bios also
    The bios has a whitelist for genuine batteries, you need a genuine battery or a modded bios .
    • kalilinux25
      • Mar 2018
      • 2084
      • ZAMBOANGA SIBUGAY
      i WANTED to know where to get a moddem bios for this model
      • kalilinux25
        • Mar 2018
        • 2084
        • ZAMBOANGA SIBUGAY
        i really need a help here
          • 20689
          Try at bios-mods. https://www.bios-mods.com/forum/Thre...emoval?page=60
          • omruu9
            • Apr 2016
            • 70
            whitelist Lenovo B590 bettary
            hello i need lenovo b590 bettary whitelist im facing issue replace battery i attach old bios both ec+main with picture error
            serial of laptop :WB11741840
            P/N : 59370490
            Model Name : 20208
            • madrali
              lenovo e15 gen2 bios ? problem
              by madrali
              Model: Lenovo ThinkPad E15 Gen 2 (Intel)
              20TD-50S0KU00
              Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
              I used Lenovo's SmartBeep decoder and it returned error 0284:
              "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
              I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
              06-16-2025, 12:06 PM
            • NConstantinou
              LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
              by NConstantinou
              Dear all,
              i have the above laptop which had a problem with battery. i replaced it with a compatible one..
              the laptop DOES NOT POWER ON..
              with it old battery it does power on.
              i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
              when i shutdown the laptop does not power on.
              does anyone have any solution!
              when is not power on the usb c voltage tester shows 5v 1.3A
              when i disconnect battery and power on and then connect battery the tester...
              12-10-2024, 04:52 AM
            • jendkkd jeje
              Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
              by jendkkd jeje
              So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
              I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
              10-11-2024, 03:12 PM
            • mximiliandz
              help bios lenovo ideapad s145-14iil type 81w6
              by mximiliandz
              Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
              06-20-2025, 06:50 AM
            • konradx
              Lenovo Thinkpad T15 Touchscreen problem bios
              by konradx
              i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
              That is my DUMP.
              My device:
              SN: PF29Y4N6
              1s20S7S2WF00PF29Y4N6
              MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
              09-06-2024, 01:33 AM
