lenovo B590 problem about battery/ bios also
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    I have a LENOVO B590 Ive replace it a new battery , but it says the battery installed is not supported by this system wand will not charge.Please replace the battery with the correct lenovo battery for this system.,
    If someone has this kind of problem, Ive read some forum they said its a bios issue that u need to upgrade its bios ..
    • 22012
    Re: lenovo problem about battery/ bios also
    The bios has a whitelist for genuine batteries, you need a genuine battery or a modded bios .
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      i WANTED to know where to get a moddem bios for this model
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        i really need a help here
          • 22012
          Try at bios-mods. https://www.bios-mods.com/forum/Thre...emoval?page=60
          • omruu9
            • Apr 2016
            • 70
            whitelist Lenovo B590 bettary
            hello i need lenovo b590 bettary whitelist im facing issue replace battery i attach old bios both ec+main with picture error
            serial of laptop :WB11741840
            P/N : 59370490
            Model Name : 20208
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
            • bbusterscruggs
              Lenovo B590 20208 Bios Problem
              by bbusterscruggs
              Hello, I wanted to update my laptop's BIOS from h1et40ww to h9et92ww. The website says I need to install h9et75ww first, so I tried installing that version first, but the installation failed and when I press the power button, the laptop momentarily turns on and off (the power light immediately flashes). I tried the crisis files with Fn+R but they didn't work (it works for about 30 seconds with Fn+R but nothing displays on the screen). How can I get a BIOS update file that I can use with Fn+R? Maybe I'm naming the files I put on the USB drive incorrectly. The ones I've tried are bios.bin, bios.cap,...
              09-15-2025, 11:57 AM
            • c.daniel
              Lenovo V310-15IKB weird bios problem...
              by c.daniel
              Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
              sn LR09493E
              MB DAOLV6MB6F0 REV. F
              The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
              Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
              Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
              08-22-2025, 05:39 AM
            • madrali
              lenovo e15 gen2 bios ? problem
              by madrali
              Model: Lenovo ThinkPad E15 Gen 2 (Intel)
              20TD-50S0KU00
              Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
              I used Lenovo's SmartBeep decoder and it returned error 0284:
              "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
              I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
              06-16-2025, 12:06 PM
            • MaxonDomkrat
              Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
              by MaxonDomkrat
              Hi everyone.
              I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
              07-30-2025, 01:27 PM
