820-4668-A Please clear lock need urgent
  • Murtaza527
    • May 2018
    • 257
    • Malaysia
    please clear bios lock for this bios i try to open with flash image tools its give error otherwise i have a working bios i change the BIOS Region part with that and can solve this but when i open in flash image tools then give error
    Component Section : invalid flash component density 12!
    please clean the password
  • simpleway
    • Feb 2016
    • 22
    • algerie
    Re: 820-4668-A Please clear lock need urgent
    this dump is for Dell Optiplex 9010
    • Murtaza527
      • May 2018
      • 257
      • Malaysia
      yes thanks finally i find the original bios chip and now already done
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • brock-s
        MSI A520M-A Pro with "U-Key" power-on lock removal
        by brock-s
        I've searched the forums, including review of the "BIOS Guides, Methods, Resources and Tools" section but could not find anything regarding this problem. Additionally, I could not find a thread related to a U-Key lock on an MSI motherboard (or any other brand board for that matter).
        I'm working on an MSI A520M-A Pro (aka MS-7C96 ver1.1) motherboard that displays "Warning!!! Please insert USB key press any key to check." upon power-on. This appears to be caused by a setting in the BIOS for "U-Key" being enabled. The owner states they didn't enter the...
        09-01-2025, 12:35 PM
      • spmetroil
        Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
        by spmetroil
        I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
        The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
        I have a CH341A programmer and I already attempted the following steps:
        1. Identified the correct chip (W25Q128, 3.3V SPI flash).
        2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
        3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
        08-19-2025, 09:23 AM
