Bios bin pm_a_hpc_s_mv_mb_v1
  • NConstantinou
    • May 2017
    • 354
    • Cyprus
    i need bios bin file for HP PM_A_HPC_S_MV_MB_V1 motherboard
  • peste
    • 13931
    • ROMANIA
    Re: Bios bin pm_a_hpc_s_mv_mb_v1
    try,,
    • NConstantinou
      • May 2017
      • 354
      • Cyprus
      Thanks but i can not open it.
      winrar says file is damaged
      • peste
        • 13931
        • ROMANIA
        at me it opens with winrar, it uses winzip it can open.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          upgrade your winrar version
          • coder78
            • Aug 2015
            • 67
            • turkey
            Originally posted by peste
            try,,
            thanks
            • to5it0
              by to5it0
              10-24-2025, 01:35 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • maanee11
              Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
              by maanee11
              Hello Everyone,
              I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
              It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
              In the website, you can only see specs etc.
              I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
              11-08-2025, 04:08 AM
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • Forest79
              by Forest79
              07-23-2023, 07:39 AM
