Re: 820-00165 2017 emc 3178 bios
Is it possible to write a bios bin file that works for someone else same year and EMC on yur own system and it works just fine ?
try another keyboard ....Leave a comment:
Thank you very much, I was able to restart the macbook.
But my initial problem persists, namely an inconsistency in the keyboard (uppercase and lowercase keys reversed) as well as in the functionality of the left click.
Thanks again for the help.Leave a comment:
Attached FilesLeave a comment:
After the repair following a liquid damage, the macbook turns on but it reacts strangely.
I tried to work on the BIOS but without success.
I'm really stuck on this topic, thank you for your help.Attached FilesLeave a comment:
try..Attached FilesLeave a comment:
I'm sending thanks a lot serial number FVHZMM6NJ1WKAttached FilesLeave a comment:
which bios ?? ... who are you asking ??
https://www.badcaps.net/forum/showthread.php?t=103570Leave a comment:
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
