Hi everybody i need UX305UA i7 6500 bios dump .from i5 UX305UA i got black screen.Original i7 bios working but have random shutdown.
Re: UX305UA i7 6500 bios dump
i5 or i7 shouldn't matter, as long as ME region is clean. Revision of the board may matter though.
Post your old dump and confirm board revision if applicable.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
Hi sir
thank you for your fast reply.
i know how to clean me region but in this file i think cant do something.the only can do is download 6mb orignal bios from asus and with hex editor import it to my bin file.But still the fan is full working 4889 rpm and cpu tempratures are low 30 C degrees. i attach original biosAttached FilesPremium supporters get full download access and other benefits.
Try this bios-asus update file merged with your bios. Did you cut the extra 2 bytes at the beginning of update file before merging it??Attached FilesPremium supporters get full download access and other benefits.
Try this one .Attached FilesPremium supporters get full download access and other benefits.
hi guys.Thank you for your messages.i have tried all bios but still problem remain fan works full and have random shut downs.i dont have backup of original bios but intel managment interface driver is installed correct without exclanation mark.i also replaced the 8pin thermal ic but problem remain.motherboard is celan without water or other fluid.
But i believe it is bios related issue.
Any idea?Comment
Try this bios.hi guys.Thank you for your messages.i have tried all bios but still problem remain fan works full and have random shut downs.i dont have backup of original bios but intel managment interface driver is installed correct without exclanation mark.i also replaced the 8pin thermal ic but problem remain.motherboard is celan without water or other fluid.
Any idea?Attached FilesPremium supporters get full download access and other benefits.
hi smdflea thank you for you file.I also tried it with no luck.But i finally fixed the problem with uefi tool -Fit tool -original bios and 11.0.0.1169_CON_LP_C0_NPDM_PRD_EXTR.bin
Now working as should.
Thank you all guys for your helpComment
by TrademarkHello everyone,
I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
This is NOT a BIOS password removal request.
I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
Laptop Information- Model: Acer Predator Triton 16 PT16-51-99GL
- Motherboard: DA0ZQDMB8AE Rev. E
- Main SPI flash: Winbond W25Q256JVEN (32MB)
- Secondary
Channel: BIOS Requests ONLY!
by AhariHi all,
I...-
by JunhijamHi, I'm new to all of this so I hope I'm doing correctly and not breaking any rules.
I need help for my MSI PRO B660M-A DDR4 motherboard BIOS dump.
The motherboard got bricked during BIOS update due to a power cut in my village while updating BIOS. Now the PC is not booting. Fans kept spinning and no display is coming.
A local technician said I need the full BIOS dump/file for this motherboard.
My Motherboard model is:
MS-7D43 REV 1.0
The Bios chip is:
MXIC
MX25U25673GZ4140
Please, if anyone has the same board...-
by Boomer501Hi everyone,
I wanted to share my experience fixing the BIOS on an Asus FA608UH laptop. Hopefully, this information and the attached dumps will save someone else a lot of time.
Laptop Specifications:- Model: Asus FA608UH
- Motherboard Platform: Quanta JW1 (DANJWIMBAA0 REV:A)
The laptop came to me from another repair shop. They had flashed a clean dump from the official website but forgot to prepare it or transfer the original DMI block. As a result, all the original factory data was completely lost, and they didn't backup the original corrupted BIOS file either....-
by zathanHi everyone,
I'm looking for a BIOS dump or older BIOS that still supports the AMD A6-9500E (Bristol Ridge) on a Biostar A320MH 2.0 Ver. 6.1 motherboard.
Here's what happened:- Motherboard: Biostar A320MH 2.0 Ver. 6.1
- Original CPU: AMD A6-9500E
- Original BIOS version: Reported as 5.15
- The A6-9500E worked normally before the BIOS update.
I updated the BIOS using the built-in BIOS Flasher to A32GS311.BSS. After the update:- ❌ AMD A6-9500E powers on but shows a black screen (no display).
- ✅ Ryzen 3 2200G boots and works normally.
I've already tried:- Clearing
07-12-2026, 10:36 PM - Loading...
