need bios dump for toshiba tecra R950
This topic is closed.
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    hello
    i need bios dump for toshiba tecra r950
    FAL2SY2 A3245 A
    or if sombody could remove the password here is my old
    thank you
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    Re: need bios dump for toshiba tecra R950
    Hello friends
    Nobody to help
    Still waiting
    • piernov
      • Jan 2016
      • 4439
      • France
      Supervisor password is most likely in MEC1618.
      • outsider
        • Apr 2014
        • 104
        • localhost
        Toshiba Tecra R950 - PASSWORD
        Toshiba Tecra R950-1EK
        PC Serial No. = 4D083707H
        Challenge Code = UF9F8-VEDAC-HN73R-C92LT-908G9
        Response Code =
        I need please challenge code for unlock bios. Someone is able to generate code based on SN and challenge code?
        Maybe you just need to write a clean BIOS dump?? or the password in the EC / KBC?
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          Re: Toshiba Tecra R950 - PASSWORD
          Password in kbc. Somebody has the generator but asks money for every code.
          • outsider
            • Apr 2014
            • 104
            • localhost
            If i reprogramming KBC other dump the password was remove ?
            • alext28
              • May 2020
              • 51
              Toshiba Tecra R950 challenge code
              I need help for have a response code for my laptop please
              Toshiba Tecra R950
              PC serial No. = ZC057439H
              Challenge Code = 6A9GD-HR4QU-PR56C-GVD3C-A8PEY
              Thanks !!
              • msl77
                • Jun 2014
                • 10
                • yemen
                Originally posted by alas3376
                Hello friends
                Nobody to help
                Still waiting
                tester goood work
                • teqcom
                  • Nov 2015
                  • 311
                  • malasyia
                  Need Toshiba Tecra R950 Response Code
                  Toshiba Tecra R950 need Response thx
                  Serial No= 8C122552H
                  Challenge Code=Q7K0F-ACJ6E-HCBLG-CB3HL-FE2XE
                  • egteam
                    • May 2018
                    • 5
                    • turkey
                    https://drive.google.com/file/d/1yOF...ew?usp=sharing
                    • jacospama
                      • Aug 2019
                      • 240
                      • Ghana
                      toshiba tecra r950 bios lock
                      toshiba tecra r950 bios SUPERVISER PASSWORD . board No.( fal25y2 a3245 a)
                      Part No.(PT534U-0EM05G).
                      HOW DO I UNLOCK IT.
                      • mhmed2090
                        • May 2017
                        • 33
                        • alex
                        try this
                        • kamalkharbanda
                          • Jun 2013
                          • 92
                          • India
                          Originally posted by mhmed2090
                          try this
                          your file is working but not remove password
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            Read the rules before posting:
                            BIOS guides, methods, resources and tools
                            Password removal by laptop brand
                            3.10. Toshiba
                            3.10.1. Consumer
                            A lot of Toshiba consumer laptops have a jumper on the motherboard that needs to be shorted before boot to clear the password.
                            3.10.2. Business
                            Most Toshiba business laptops do not have a jumper, and the password is stored inside a protected region of the EC. See affected models: https://www.badcaps.net/forum/showpo...2&postcount=19
                            Either you need a donor EC without password, or you need to unlock through challenge-response.
                            Response generator is not available publicly, however, some generous people may be able to generate a response for you. Ask in this thread: https://www.badcaps.net/forum/showthread.php?t=79489
                            Laptop must not be rebooted, the challenge will change.
                            Become a Badcaps supporter
                            Thanks to all supporters.
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • mkdj
                              by mkdj
                              Dear all,
                              10-19-2025, 04:41 AM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                              Toshiba Tecra Tecra X40-E-114 Netbook Specification for Upgrade or Repair
                              This specification for the Toshiba Tecra Tecra X40-E-114 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tecra X40-E-114 boardview and Tecra X40-E-114 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-06-2024, 06:42 AM
                            • aze2eza
                              [Request] BIOS Unlock for Toshiba Tecra X40-E-19
                              by aze2eza
                              I need help unlocking the BIOS of a Toshiba Tecra X40-E-19, Serial Number: 2K199216H.
                              The BIOS is locked (possibly password protected), and I have already dumped both the original BIOS and EC chips using an RT809H programmer.
                              Board model: FURRSY1 A4481A
                              I'm requesting assistance in removing the password or unlocking the BIOS while keeping system data intact.
                              Any help or patched file would be greatly appreciated.
                              Thank you!...
                              04-30-2025, 03:35 AM
