BIOS lenovo ideapad 330S-14IKB
  • nicoreflex
    • Aug 2019
    • 3
    • argentina
    Marca: Lenovo ideapad 330S-14IKB
    Board model: 330S_KBL_v06
    winbond: 25064jvsiq1749
    the original since on the lenovo page is the update in .exe
    I need the original .bin to burn the bios again ...
    Thank you so much!!!!!
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Se necesita BIOS lenovo ideapad 330S-14IKB
    try and report
    • nicoreflex
      • Aug 2019
      • 3
      • argentina
      Originally posted by Claudiomfa
      try and report
      Se grabo la bios y sigue muerta.... no carga no enciende... los voltajes llegan bien... supuestamente el dueƱo estaba actualizando la bios y se le apago..
      Lo raro es que con el .bin que me pasastes no lo pude grabar sobre el bios original ya que daba error... pero en un bios nuevo si lo pude grabar se probo sin resultados... el original se pudo hacer backup pero no se pudo grabar nuevamente....
        • 22425
        This is an english language forum,use google translate https://translate.google.com
        The bios was recorded and still dead .... no load does not turn on ... voltages arrive well ... supposedly the owner was updating the bios and turned off ..
        The strange thing is that with the .bin that you passed me I could not record it on the original bios since it gave error ... but in a new bios if I could record it it was tested without results ... the original could be backed up but not could record again
        • Claudiomfa
          • Nov 2015
          • 455
          • Portugal
          Post your original bios dump and i will see if i repair them
          This laptop have kbc or secand bios chip?
          • microfix
            • Aug 2016
            • chile
            BIOS Lenovo ideapad 330S-14IKB
            Modelo: 81F4
            Modelo de placa: 330S_KBL_v09 REV MP
            • pacwcbs
              • Nov 2015
              • 28
              • Dominican Republic
              Re: BIOS Lenovo ideapad 330S-14IKB
              • Marc97
                • Jan 2016
                • 189
                • Phillipines
                original file 330s-1kib i5 8thgen
                • djharold
                  • Aug 2015
                  • 247
                  • COLOMBIA
                  try and report
                  thankyou
                  • kingaarbi
                    • Apr 2016
                    • 129
                    • Malaysia
                    lenovo 330S-14IKB No Display
                    lenovo 330S-14IKB
                    330S_KBL_MB_V09
                    Rev MP
                    P\N 431204237090
                    S/N PF1FUJAJ
                    No Display
                    Build Plss..
                    • neandertool
                      • Mar 2022
                      • 7
                      Lenovo Ideapad 330S-14IKB - Model 81F4
                      Model Name: 81F4
                      S/N: YD04VU18
                      Motherboard Label:
                      330S-KBL-I5-4G-4202811-5000-3453
                      P/N: 431204222050
                      BIOS Flash Chip: Winbond 25Q64JVSIQ
                      I wanted to clear the BIOS password that my son had added to his laptop (and had forgotten). After reading about clearing the Lenovo laptop BIOS passwords, it seemed that I should be able to dump the existing BIOS and then simply re-flash my BIOS dump back to the chip. I read that this process should erase the password as it is stored in a separate area of the BIOS chip that would be erased when flashing the existing image back to the chip.
                      I was able to dump the chip successfully several times using a raspberry pi 3 and Flashrom. I verified that all of the dumps were identical before proceeding. I re-flashed the chip with the same image and tried to boot the laptop. Upon turning on the laptop the white power LED at the top-right of the keyboard lights up white, but I have a black screen with no backlight, CPU fan will not turn on, & the CPU gets very warm. Power is provided to USB ports. After a minute or two the laptop turns off. Pressing the caps lock key does not toggle the caps lock light. There are no BIOS POST beeps.
                      Thinking that the original BIOS may have become corrupted I extracted the WinKabylake_m.fd flash file from the Lenovo BIOS update using Innoextract & InsydeImageExtractor. I copied my Windows Key and DMI info from my original BIOS image and inserted them into the extracted BIOS update image using HxD. After flashing this image back to the chip I get exactly the same result.
                      I have attached my original BIOS dump, the untouched BIOS update installer, and my altered BIOS update image file
                      Could someone please have a look at my BIOS files and see if there are any obvious problems that might be preventing the laptop from booting.
                      Thanks for your help
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12527
                        Re: Lenovo Ideapad 330S-14IKB - Model 81F4
                        Did you remove the bios chip from the main board ? If so, double check that you didn't accidentally blow away small components around the bios chip.
                        ​https://www.badcaps.net/donate
                        • peste
                          • Dec 2016
                          • 14052
                          • ROMANIA
                          bios extracted from the Lenovo site update
                          DMI 200000 - 20022F
                          • neandertool
                            • Mar 2022
                            • 7
                            Thanks, that was a good thing to check, but not the problem sadly.
                            • neandertool
                              • Mar 2022
                              • 7
                              DMI 200000 - 20022F
                              Thanks for the bios image, but unfortunately it didn't work. I guess I need to move onto finding a fault with the hardware that I must have created while removing the bios chip.
                              • Atiq
                                • Dec 2017
                                • 78
                                • India
                                Re: BIOS lenovo ideapad 330S-14IKB
                                Hello Friends,
                                I lenovo ideapad powers on and powers off is seconds
                                330S-14IKB
                                can someone fix my bios.
                                All help will be very appreciated.
                                Thank you very much
                                • peste
                                  • Dec 2016
                                  • 14052
                                  • ROMANIA
                                  Originally posted by Atiq
                                  Hello Friends,
                                  330S-14IKB
                                  Thank you very much
                                  you have everything you need at post #13...
                                  • Atiq
                                    • Dec 2017
                                    • 78
                                    • India
                                    Thank you for your reply i tried #13 bios but only once display came again after restart problem repeated same.
                                    • lapfix
                                      • Mar 2020
                                      • 2764
                                      • my workshop
                                      i Don't think it s a bios issue , try to post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23
                                      • Atiq
                                        • Dec 2017
                                        • 78
                                        • India
                                        thank you for your quick reply.
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • Popel1083
                                          Lenovo IdeaPad U330p Read Bios than Bios Password Remove
                                          by Popel1083
                                          I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
                                          SN: QB08570065
                                          MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
                                          08-06-2024, 05:52 PM
                                        • -danger-
                                          LENOVO IdeaPad 1 15ALC7 Bios Password
                                          by -danger-
                                          Hello.
                                          Please, help me to remove bios password.
                                          Here is bios dump.
                                          Model: LENOVO IdeaPad 1 15ALC7
                                          S/N: PF4QG7XP
                                          MB: JS471/JS573 Rev: 1.0
                                          Thanks in advance.
                                          LENOVO IdeaPad 1 15ALC7.zip...
                                          06-07-2025, 10:01 AM
