Lenovo ThinkPad T540P LKM-1 SWG2 MB 12308-2 48.4L016.021 PASSWORD
  • fyaagoub
    • Dec 2016
    • 269
    • maroc
    This bios for Lenovo ThinkPad T540P LKM-1 SWG2 MB 12308-2 48.4L016.021 is currently supervisor locked I search the methode to unlock this bios thanks
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Lenovo ThinkPad T540P LKM-1 SWG2 MB 12308-2 48.4L016.021 PASSWORD
    Supervisor password is in EC. Cannot be unlocked in BIOS directly.
    • fyaagoub
      • Dec 2016
      • 269
      • maroc
      Mec 1633l but there is patch bios methode
      • fyaagoub
        • Dec 2016
        • 269
        • maroc
        Originally posted by fyaagoub
        je cherche comment patcher le bios si possible
        thanks
        • fyaagoub
          • Dec 2016
          • 269
          • maroc
          hardware id lenovo T540P
          • fyaagoub
            • Dec 2016
            • 269
            • maroc
            Ok thank you
            • vinsun0399
              • Aug 2019
              • 38
              • Jakulin
              Originally posted by Nico Latour
              next time you need hw id code send me pm
              kindly help me unlock
              • pokyss1
                • Mar 2019
                • 58
                • TUNISE
                hello I have the same machine after the bios flash I still have the password
                • mohamed said
                  • Apr 2015
                  • 30
                  • egypte
                  Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
                  I need T540p
                  There is password in bios.
                  Could you help me try patching it
                  • mohamed said
                    • Apr 2015
                    • 30
                    • egypte
                    I need T540p autopatch pass
                    I need autopatch T540p
                    • mohamed said
                      • Apr 2015
                      • 30
                      • egypte
                      wark fil okkkkkkkkk
                      T540p
                      • dello
                        • Oct 2019
                        • 5
                        • maroc
                        LENOVO THINKPAD T540P
                        I flashed a patched bin file now the laptop is OFF the fan spin 5 sec and stop
                        same things with original bin file.
                        Any idea about the error?
                        • peterzz2007
                          • Nov 2021
                          • 19
                          • Slovakia
                          T540p BIOS black screen issue
                          Hello all,
                          laptop turns on,but with black screen (screen tested good on another maschine).
                          Can anyone take a look and patch eventually attached dump pls. ?
                          Thank you!
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12190
                            Re: T540p BIOS black screen issue
                            Originally posted by peterzz2007
                            Hello all,
                            Thank you!
                            T540p Laptop (ThinkPad)
                            • peterzz2007
                              • Nov 2021
                              • 19
                              • Slovakia
                              Thank you Hoaca388,
                              but it is power cycling every 3 seconds now...
                              • peterzz2007
                                • Nov 2021
                                • 19
                                • Slovakia
                                OK,since original bios dump was a nogo i used both chips from machine with fried board.
                                And it`s working just fine
                                • bushmann
                                  • Feb 2014
                                  • 147
                                  • Slovakia
                                  Autopatcher not work for this model
                                  Autopatcher wrote error in implementing process.
                                  How I can direct connect to MEC1633L .
                                  I have from Vertyanov JIG programer, but not have points where connect.
                                  • bushmann
                                    • Feb 2014
                                    • 147
                                    • Slovakia
                                    Unfortunately, I could not find any information on the Internet for the T540p model, which points on the board should be used to connect the programmer.
                                    So I had to figure it all out myself and here is my result.
                                    As a programmer, I used the already mentioned JIG from Vertyanov.
                                    Everything worked the first time.
                                    of course I had to have power connected to the laptop.
                                    If you have a motherboard outside, don't forget to connect an additional board with USB and RJ45.
                                    If you do not connect this additional board, your NB will not turn on.
                                    To remove the password in the BIOS, just overwrite the eeprom area in the MEC1633 chip with the attached file.
                                    • Paul.Junge2020
                                      • Feb 2023
                                      • 36
                                      • Ukraine
                                      Hello. Help remove bios password. after the patch, I return the file to the chip - a black screen, and 5 sigals
                                      Lenovo t540p
                                      • Andreasbest
                                        • Aug 2014
                                        • 1193
                                        • Hellas ( Greece )
                                        wark fil okkkkkkkkk
                                        T540p
                                        Works like a charm (enough to replace DXE)
                                        Thank you!
                                          Lenovo ThinkPad T540p Grade Barga1n+ Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T540p Grade Barga1n+ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T540p Grade Barga1n+ boardview and T540p Grade Barga1n+ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 09:01 AM
                                        • Maxpower3
                                          Brand name and Model Type for Lenovo error 2202 product name is invalid
                                          by Maxpower3
                                          Info for error 2202 LenovoThinkPad models and type
                                          Extract from ThinkPad Maintenance Utilities Configuration File
                                          plnsrv.ini Version 1.01
                                          Some information that may be useful
                                          There must also be missing models, add them to the list if you know of any.
                                          Code:
                                          brand name
                                          20B1=ThinkPad Edge E445
                                          20B2=ThinkPad Edge E545
                                          20BC=ThinkPad Edge E145
                                          20BM=ThinkPad X140e
                                          20BL=ThinkPad X140e
                                          20A3=ThinkPad X230s
                                          20AH=ThinkPad X230s
                                          20AK=ThinkPad X240s
                                          20AJ=ThinkPad X240s
                                          02-21-2024, 10:27 AM
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
