Working
Hp 8560p Working dump
by FedorovVMSI Alpha 15 B5EEK-237XRU SN:K2209N0193161
Came without initialization. Before that, it was not under repair. With BIOS from the official website, there is a start Ok, after a while the fans gain speed and the laptop turns off.
The cooling system is cleaned, the contact spot is good.
I need a working dump from laptop to check.
This is an original, not working dump....-
Channel: BIOS Requests ONLY!
03-10-2024, 07:26 PM -
by bobrinoHi, guys. Maybe, anybody has working dump ene kb9022q d for this laptop (not from update)? Motherboard la-f661p. Don't working keyboard and tauchpad. I want to downgrade bios ec version. Many thanks
by Bimad99Hello everyone,
i need a working bios for an HP elitedesk 705 g2 base model sff machine, the problem is the machine turns on but there is no display.
SERIAL NUMBER : CZC615CDTY
BOARD MODEL NUMBER : 798073-001 REV 0C
THE BACKUP DUMPS ARE ATTACHED DOWN BELOW.
And this model has three SPI FLASH ICs, two 64mb (U19 and U68) and one 8mb (U11), i need clarification which one is the main bios chip ???!!!...-
05-19-2024, 04:51 AM -
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
- Loading...
