Acer travelmate p246 series bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 11659
    Originally posted by SUGATH RAJAPAKSE
    Acer travelmate p246 series TM246-M DA0ZQ0MB6E0 REV E No display
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • lonel13
      • Oct 2021
      • 15
      • phillipines
      Originally posted by peste
      Re: Acer travelmate p246 series bios
      try..
      thanks it works perfectly
      • BIOSSASI
        • Dec 2023
        • 26
        • SRILANKA
        PleasE CLEAR ME and Rebuild
        No Power , No Chrging Light without battery. But When insert battery and plug charger Orange Led Comming.
        Power Button Not Respond
        All Voltages are Present.
        No Fan Spin , I tried several bios , same
        board : DA0ZQ0MB6E0 REV:E ( MODEL : ZQ0)
        • peste
          • Dec 2016
          • 12676
          • ROMANIA
          post S/N, full name and model, ,etc.
          • BIOSSASI
            • Dec 2023
            • 26
            • SRILANKA
            Model : Travelmate P246 Series
            RMN : ZQ0
            TMP246-M-55BZ MFG DATE : 2014/06/23
            S/N : NXV9VSG0064252BC547600
            SNID : 42517928476
            BOARD : DA0ZQ0MB6E0 REV:E
            • BIOSSASI
              • Dec 2023
              • 26
              • SRILANKA
              #26
              RMN : ZQ0
              SNID : 42517928476
              Kind Request to clean me & rebuild. Thank You
              • peste
                • Dec 2016
                • 12676
                • ROMANIA
                #27
                RMN : ZQ0
                SNID : 42517928476
                try..
                • BIOSSASI
                  • Dec 2023
                  • 26
                  • SRILANKA
                  #28
                  try..
                  Thank You Verymuch. It worked 100%, Respect for your help
                  • EbrahimSiami
                    Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                    by EbrahimSiami
                    I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                    **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                    **What I have tried so far:**
                    1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                    07-02-2025, 02:31 PM
                  • Wg188
                    ACER Veriton Z4660G AIO bios help
                    by Wg188
                    I have an Acer veriton Z4660G all in one pc,
                    Model: Z4660G-I5850H1 (VZ4660G_W)
                    Need bios dump and schematic would save my life !
                    to make a long story short I bought this all in one used
                    with a broken lcd, with the objective of making a custom desktop out of it
                    ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                    06-17-2023, 02:20 PM
                  • maralexbar
                    How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                    by maralexbar
                    I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                    It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                    If anyone knows how to force the external monitor as primary for Notebooks of those models
                    11-02-2024, 09:18 AM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    Today, 02:17 PM
                  • James194zt
                    Acer Nitro 50-640E Corrupted BIOS Dump
                    by James194zt
                    My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                    All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                    04-28-2025, 03:29 PM
