Acer travelmate p246 series bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Originally posted by SUGATH RAJAPAKSE
    Acer travelmate p246 series TM246-M DA0ZQ0MB6E0 REV E No display
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • lonel13
      • Oct 2021
      • 19
      • phillipines
      Originally posted by peste
      Re: Acer travelmate p246 series bios
      try..
      thanks it works perfectly
      • BIOSSASI
        Creator 💀
        • Dec 2023
        • 35
        • SRILANKA
        PleasE CLEAR ME and Rebuild
        No Power , No Chrging Light without battery. But When insert battery and plug charger Orange Led Comming.
        Power Button Not Respond
        All Voltages are Present.
        No Fan Spin , I tried several bios , same
        board : DA0ZQ0MB6E0 REV:E ( MODEL : ZQ0)
        • peste
          • 13924
          • ROMANIA
          post S/N, full name and model, ,etc.
          • BIOSSASI
            Creator 💀
            • Dec 2023
            • 35
            • SRILANKA
            Model : Travelmate P246 Series
            RMN : ZQ0
            TMP246-M-55BZ MFG DATE : 2014/06/23
            S/N : NXV9VSG0064252BC547600
            SNID : 42517928476
            BOARD : DA0ZQ0MB6E0 REV:E
            • BIOSSASI
              Creator 💀
              • Dec 2023
              • 35
              • SRILANKA
              #26
              RMN : ZQ0
              SNID : 42517928476
              Kind Request to clean me & rebuild. Thank You
              • peste
                • 13924
                • ROMANIA
                #27
                RMN : ZQ0
                SNID : 42517928476
                try..
                • BIOSSASI
                  Creator 💀
                  • Dec 2023
                  • 35
                  • SRILANKA
                  #28
                  try..
                  Thank You Verymuch. It worked 100%, Respect for your help
                  • Smoke20
                    • Jul 2020
                    • Philippines
                    #29
                    RMN : ZQ0
                    TMP246-M-3088 DATE : 2016/03/09
                    S/N : NXV9VSP02961003E847600
                    SNID : 61001600476
                    BOARD : DA0ZQ0MB6E0 REV E
                    ISSUE : NO DISPLAY
                    • peste
                      • 13924
                      • ROMANIA
                      #30
                      try..
                      • EbrahimSiami
                        Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                        by EbrahimSiami
                        I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                        **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                        **What I have tried so far:**
                        1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                        07-02-2025, 02:31 PM
                      • Wg188
                        ACER Veriton Z4660G AIO bios help
                        by Wg188
                        I have an Acer veriton Z4660G all in one pc,
                        Model: Z4660G-I5850H1 (VZ4660G_W)
                        Need bios dump and schematic would save my life !
                        to make a long story short I bought this all in one used
                        with a broken lcd, with the objective of making a custom desktop out of it
                        ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                        06-17-2023, 02:20 PM
                      • Zelu
                        ACER TRAVELMATE P645-S-54 N U Bios password request
                        by Zelu
                        Model : TMP645-S-54 NU
                        S/N: NXVATEK01654900E2D3400
                        MFG DATE 2015/12/02
                        I had this laptop for years, came with windows 7, never bothered to check bios access until now, it is locked from the factory.
                        I need access to the bios to choose another boot devices to be able to update OS.
                        When trying to unlock the bios with 3 failed password attempts prompts a message with a 8 digit key (93415130) to unlock the password. Using the ones provided by biosbug does not work.
                        I have seen that somebody with a similar laptop (another model of travelmate...
                        10-04-2025, 06:42 PM
                      • Kjell
                        Samsung Series 9 - BIOS issue
                        by Kjell
                        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                        08-01-2025, 09:15 AM
                      • maralexbar
                        How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                        by maralexbar
                        I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                        It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                        If anyone knows how to force the external monitor as primary for Notebooks of those models
                        11-02-2024, 09:18 AM
