Acer travelmate p246 series bios
  • kalilinux25
    • Mar 2018
    • 2069
    • ZAMBOANGA SIBUGAY
    Hi this board has no power but I tired diffrent bios it turns on but it has no display maybe incompatible bios
    BOARD : DA0ZQ0MB6E0 REV.E
    SNID: 55302308576
    I HAVE BACKUP TO.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer travelmate p246 series bios
    TM P246 should have Quanta ZQ0B mb. Are you sure its Quanta ZQOM mb??
    • kalilinux25
      • Mar 2018
      • 2069
      • ZAMBOANGA SIBUGAY
      Yes sit the cover says p246 the board says its a ZQ0M
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Try this bios.
        • kalilinux25
          • Mar 2018
          • 2069
          • ZAMBOANGA SIBUGAY
          Try this bios.
          HAS POWER ,FAN NOT SPINNING , NO DISPLAY, 304 MILIAMP consuming
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            The bios i've uploaded is acer virgin bios merged with your dump. Your SNID: 55302308576 shows "TravelMate P246-M" on acer site. So the bios i rebuilt is correct. I think you have problem in mb hardware and its no more related to bios. Btw, check whether kbc is programmable.
            • kalilinux25
              • Mar 2018
              • 2069
              • ZAMBOANGA SIBUGAY
              How can I check it sir?
              IT8587E CODE
                • 20419
                IT8587E CODE
                schematic https://www.badcaps.net/forum/showpost.php?p=697265
                Programmable and non-programmable SIO list https://www.badcaps.net/forum/showthread.php?t=66963
                • b seshu
                  • Dec 2017
                  • 3
                  • india
                  acer travelmate p246m-m bios bin file can u send
                  • peste
                    • Dec 2016
                    • 12314
                    • ROMANIA
                    post the original laptop bios
                    • jimore
                      • Nov 2020
                      • 177
                      • mexico
                      pls help me clean.. No display
                      • peste
                        • Dec 2016
                        • 12314
                        • ROMANIA
                        try..
                        • jimore
                          • Nov 2020
                          • 177
                          • mexico
                          try..
                          thanks bro
                          perfect working bios..
                          • gyro10
                            • Sep 2020
                            • 20
                            • Philippines
                            try..
                            tnx work 100%
                            • Sabina
                              • May 2022
                              • 67
                              • philippines
                              Travelmate p246m-m z8b bios
                              da0z8bmb6c0 rev c
                              s/n: nxva88sp00343714d1f7600
                              snid: 43708527976
                              no display
                              • peste
                                • Dec 2016
                                • 12314
                                • ROMANIA
                                da0z8bmb6c0 rev c
                                snid: 43708527976
                                no display
                                try..
                                • Sabina
                                  • May 2022
                                  • 67
                                  • philippines
                                  thanks alread tried still a no go ,. maybe something else causing the problem
                                  • iwan hariadi
                                    • May 2024
                                    • indonesia
                                    please help clean it, no display
                                  • iwan hariadi
                                    • May 2024
                                    • indonesia
                                    Travelmate p246m-m-34JD
                                    da0z8bmb6d0 rev d
                                    s/n: nxvA9SN01054802D7F7600
                                    snid: 54801164776
                                    no display, no fan, 0.42 Ah,
                                    sometimes goes normal but now no display
                                    • SUGATH RAJAPAKSE
                                      • Sri Lanka
                                      Acer travelmate p246 series TM246-M DA0ZQ0MB6E0 REV E No display
                                      • Wg188
                                        ACER Veriton Z4660G AIO bios help
                                        by Wg188
                                        I have an Acer veriton Z4660G all in one pc,
                                        Model: Z4660G-I5850H1 (VZ4660G_W)
                                        Need bios dump and schematic would save my life !
                                        to make a long story short I bought this all in one used
                                        with a broken lcd, with the objective of making a custom desktop out of it
                                        ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                        06-17-2023, 02:20 PM
                                      • maralexbar
                                        How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                                        by maralexbar
                                        I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                                        It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                                        If anyone knows how to force the external monitor as primary for Notebooks of those models
                                        11-02-2024, 09:18 AM
                                      • James194zt
                                        Acer Nitro 50-640E Corrupted BIOS Dump
                                        by James194zt
                                        My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                        All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                        04-28-2025, 03:29 PM
                                        Acer TravelMate P2 TMP215-53-7261 Notebook Specification for Upgrade or Repair
                                        This specification for the Acer TravelMate P2 TMP215-53-7261 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate P2 TMP215-53-7261 boardview and TravelMate P2 TMP215-53-7261 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        09-07-2024, 05:20 AM
                                      • simo
                                        ACER CHROMEBOOK CB317-1H series bios need
                                        by simo
                                        Hi eveyone,
                                        please bios dump neeeded for this machine
                                        MODEL : CB317-1H C8HR
                                        serial number : NXAQ2A00522607C597600
                                        SNID :22603183376
                                        Thanks in advance
                                        02-17-2025, 12:20 PM
