Help with HP 830 G5 bios
HP EndPoint Security ControlleAttached Filesif you find these attachements useful please consider making a small donation to the site
HP 830 G5
SN 5CG90260VB
HP EndPoint Security Controller has a problem, can you fix it in the bios?Attached Filesif you find these attachements useful please consider making a small donation to the site
HP EliteBook 830 G5 Notebook PCAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello and Sorry.
Hp Elitebook 830 G5
S/N:5CG9213CQH
Please repair this bios, Thanks.
XXXAttached Filesif you find these attachements useful please consider making a small donation to the site
PLEASE HELP ME
BIOS CORRUPTED
HP ELITEBOOK 830 G5
SERIAL N: 5CG907021CAttached Filesif you find these attachements useful please consider making a small donation to the site
read the rules...https://www.badcaps.net/forum/troubl...before-posting
post the S/N, motherboard model, .the full name and model of the laptop,etc..
Please, repair this bios, no image.
Thanks very muchAttached Filesif you find these attachements useful please consider making a small donation to the site
Windows Update installed the 01.28.00 Bios on my 830 G5.
Now the boot screen shows "Warning This BIOS is not for production use"
The version number is strange:
wmic bios get biosversion
BIOSVersion
{"HPQOEM - 0", "HP - 10000"}
Everything I tried to update or downgrade my BIOS under windows or within the Boot menu with an usb stick failed. invalid firmware in BIOS
in windows log file.Code:2024/07/03 14:04:08.901|00000A08|Information|CHPBiosUpdateApp::CheckInfGUID|HP System Firmware,01.00.00,01.27.00,Need to update 2024/07/03 14:04:08.964|00000A08|Information|CHPBiosUpdateApp::CheckInfGUID|Found both GUID and bin file. 2024/07/03 14:04:08.979|00000A08|Information|CHPBiosUpdateApp::MergeBinFile|Valid firmware found with C:\SWSetup\SP151317-2\Q78_012700.inf 2024/07/03 14:04:09.011|00000A08|Information|CHPBiosUpdateApp::MergeBinFile|Attempting to create firmware.bin/firmwareRecovery.bin.... 2024/07/03 14:04:09.057|00000A08|Information|CHPBiosUpdateApp::MergeBinFile|The C:\SWSetup\SP151317-2\firmware.bin is being updated 2024/07/03 14:04:09.089|00000A08|Information|CHPBiosUpdateApp::MergeBinFile|Inf File path = C:\SWSetup\SP151317-2\Q78_012700.inf 2024/07/03 14:04:09.199|00000A08|Information|HPBiosUpdate::CabFile::FindUpdateFile|Checking filename 'FIRMWARE'. 2024/07/03 14:04:11.326|00000A08|Information|CHPBiosUpdateApp::PrepareEfiFlash|EFI BIOS update is not supported by BIOS. 2024/07/03 14:04:11.327|00000A08|Information|OptionsPage::OnWizardNext|EFI flash is not supported, will attempt WMI flash. 2024/07/03 14:04:11.458|00000A08|Information|CHPBiosUpdateApp::PrepareEfiFlash|EFI BIOS update is not supported by BIOS. 2024/07/03 14:04:11.467|00000A08|Information|FlashConfirmPage::IsEfiFlashSupported|EFI flash is not supported, will attempt WMI flash. 2024/07/03 14:04:11.554|00000A08|Error |FlashConfirmPage::OnWizardNext|EFI flash not detected as supported. 2024/07/03 14:04:13.431|00000A08|Information|CHPBiosUpdateApp::ExitInstance|HpFirmwareUpdRec Return Code = 0 2024/07/03 14:04:13.462|00000A08|Information|CHPBiosUpdateApp::ExitInstance|****************** End of HpFirmwareUpdRec session ****************** 2024/07/03 14:04:13.510|00000A08|Information|CHPBiosUpdateApp::ExitInstance|
At least Windows is working fine. 😀
The Bios file from EFI-Partiton HP/BIOS/CURRENT matches (done with Beyond Comare) in large parts the bin-File q78_012800.bin
At the moment I don't have any external hardware for flashing a bios.
And I'm not the only one with that problem with the 830 G5 and the 01.28.00 Bios.
What caused the problem? Can anything else be done via software?
AgainAttached Filesif you find these attachements useful please consider making a small donation to the site
HP EliteBook 830 G5 Base Model Notebook PCAttached Filesif you find these attachements useful please consider making a small donation to the site
read..https://www.badcaps.net/forum/troubl...before-posting
post S/N... -
Help me with a working bios for hp 830 G5 MB: 6050a2930901-MB-A01.
SN:5CG9111SRJ
was updating the customer forced shutdown it never came on since other than charging.
My dumped
thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
SN:5CG8392WFY
MOBO:6050a2930901-mb-a01
I have tried cleaning ME region but no display yetAttached Filesif you find these attachements useful please consider making a small donation to the site
Please clean this bios
HP 830 G5 bios 6050A2930901-MB-A01.
Serial number: 5CG924BYSY
Original backup bios given.Attached Filesif you find these attachements useful please consider making a small donation to the site
HP 830 G5 bios 6050A2930901-MB-A01.Attached Filesif you find these attachements useful please consider making a small donation to the site
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
